LG 47LV5500 Grey Lined Screen [NOW BLACK SCREEN]
  • kazu
    • May 2015
    • 14
    Alright so to keep this brief, I have an LG 47LV5500 that when turned on, has a picture with many vertical grey lines. You could faintly see the LG logo and such in the background. It has sound. I followed this link and played around with the T-Con board and disconnected all the cables and reconnected them. After doing that, the screen now has a completely black picture. The backlight still works and everything but there are no grey lines - just a black screen.
    I figured this means I should probably buy a new T-Con board as the first attempt at fixing this TV. Am I on the right train of thought?
    Also, upon opening up this TV, there are standoffs on the left side as well as empty ports on the main board and the power supply board. That would lead me to believe another board belongs in this TV. Anybody have any ideas?
    Attached are pictures of the screen and pictures of the empty ports and such.
    Re: LG 47LV5500 Grey Lined Screen [NOW BLACK SCREEN]
    Are you getting 12VDC at both ends of the SMD fuse on the T-CON board, chassis as the GND ref?
    • kazu
      • May 2015
      • 14
      I am not getting 12v on both sides. I forget my reading but it definitely was not 12v.
      • kazu
        • May 2015
        • 14
        Not sure if this is against the rules but.....
        Bump?
          How much is the Voltage then 5V? if not 12V.
            It looks to me liked the panel has failed, have you tried with only one ribbon connected to the T-con (on the LCD side, not LVDS cable to main A/V board) at a time?
            (And, you're allowed to bump posts occasionally on here.)
            • newtothis
              • Mar 2013
              • 1556
              • england
              8 days merits a bump
              Gotta agree with Tom, Looks like the panel has died.
                I worked on SONY TV a couple weeks ago, it has bad drive ICs in the panel that caused the 12V feeding the T-CON Voltage to drop down but not enough to blow the fuse but enough to trip the shutdown, I disconnected the ribbon cables and the 12v came back and TV does not go into shutdown, then I connected the cable back in one at a time to find out which section of the panel is causing the problem.
                • kazu
                  • May 2015
                  • 14
                  I have not tried any of that but unfortunately I've become rather busy as of late and have had to closet the TV for the time being.
                  Are you guys suggesting that I disconnect all the ribbons from the T-Con and measure the voltage as I reconnect each ribbon?
                    You would only need to observe if the image changes for now
                    • pankhil
                      • Feb 2016
                      • 3
                      were you able to get the TV fixed?
                      • HTR-Informatique
                        by HTR-Informatique
                        02-09-2025, 06:51 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • VcemPzd
                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                        by VcemPzd
                        Hello everyone !
                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                        04-28-2025, 10:14 AM
                      • DaniK
                        Acer Aspire E5-574-52RH - black screen
                        by DaniK
                        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                        Symptoms are:
                        - random black screen after displaying Acer logo...
                        02-21-2024, 06:27 AM
                      • turmix
                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                        by turmix
                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                        During another reassembly, I made a mistake, and...
                        01-29-2024, 03:48 AM
