Toshiba 40D1333B - Flashing Power Light
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Toshiba 40D1333B - Flashing Power Light
    Replied.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by newtothis
      The PSU will shut down if the load on the LED's are wrong... WIth a failed LED it = the wrong load and shuts down.... With the LED's not connected again its the wrong load = Shut down
      Incorrect btw Vestel have not integrated that into these Psu's !
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • STKR123
        Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
        by STKR123
        As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
        I wonder if re-flashing the BIOS might be of any use here.
        As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
        There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
        11-03-2024, 06:58 AM
      • lapfix
        HP OMEN NO power no light
        by lapfix
        HP OMEN : DAG35DMBAD0
        NO power ,no short ,no corrusion
        Consumption : when charger plg in = 0.004 amp
        Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
        when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
        No light at power button led
        All coils resistances :
        Pl 2001 =3v measured with kohm.
        pl 2004 = 5v measured with kohm
        pl 6001 = 49.7ohm
        pl 4012 = vccsa = 24.4 ohm
        pl 3001 =...
        11-03-2025, 07:48 AM
      • CraigR
        Hp Spectra x360 Power light flashing, component id
        by CraigR
        Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
        05-07-2025, 11:06 AM
      • stephonwhyte
        un65tu7000fxza - Flashing Red Power Light
        by stephonwhyte
        un65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
        Thanks for all responses.
        11-22-2022, 12:03 PM
