Panasonic 58PZ700 logic interchange?
  • BillWatson
    • May 2015
    Hello to all, while cleaning the inside of my beloved 58PZ700 I managed to crack the logic board with extreme force (don't ask how, I already had enough embarrassment explaining the situation to my wife )
    Lucky for me I had another logic board on hand from a damaged panel I picked up years ago but the number printed on the board is slightly different.
    TNPA3983AB (original)
    TNPA3983BF
    Do you think there could be any serious damage by connecting the wrong board in this situation? on the outside the boards are identical but I'm not sure if you can just swap and change logic boards on a plasma display, any words of advice, experience or wisdom appreciated.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic 58PZ700 logic interchange?
    It's from a 50" so I'd expect the display to be incorrect
    • tw2005
      • Oct 2011
      • 6458
      58"
      Ic9001 tvrp626
      ic9003 tvrp068-7 ic 1
      ic9007 tvrp584 ic 1
      ic9304 tvrp627 ic
      50"
      ic9001 tvrp712s ic 1 pavca
      ic9007 tvrp584 ic 1
      ic9304 tvrp713s ic
      you'll need either to find another board or find somone who can remove and transplant the chips in bold. probably end up with an incorrect display image using a 50' board
      • BillWatson
        • May 2015
        Many thanks tw2005, your keen observations have probably saved my display from an untimely death! this unit was hardly used but still looks as great as ever and better than most despite its age.
        I very nearly went plug and play on this one
        • tw2005
          • Oct 2011
          • 6458
          It probably would not break it, just expect abnormal display
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
            After all of...
            07-13-2024, 08:14 PM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
