LG PDP42 goes dim after a few minutes since new ZSUS IPM
  • jesterace
    • Aug 2013
    • 87
    originally this plasma has very bad colored flickering frost pixels everywhere, and the ZSUS IPM was ticking erratically. I've installed a new ZSUS IPM module today and after switching on, all was well. Great picture. Assumed that was it, fixed... About 10 minutes later the screen went very dim/washed out with a subtle kind of back light flicker now and again. I let the TV cool down and tried again, thankfully picture went back to normal. This time it only lasted a couple of minutes though before going washed out again.
    I've taken the ZSUS out and checked the underside of the board for any bad joints. To be safe i flowed all of the solder connections all over the underside of the board. Refitted and no different. Dim/washed out after a couple of minutes.
    The ZSUS sure makes a nice loud hum with it's new IPM. I'm not entirely sure if it's normally that loud, since i have been given this tv that was being junked.
    I have a funny feeling if i keep turning the set on, the new IPM is going to go poof! Which is why i'm not running it for long each time i test. So i'm hunting for a bit of advice on the best things to start looking at. I have plenty of tools and an oscilloscope. My knowledge though is in laptop and desktop pc's unfortunately. TV's are something I've only recently started tinkering with.
    I'm assuming this is entirely a ZSUS issue? since the ZSUS deals with picture brightness?
    Any help appreciated. Fitting the IPM was a pig so id rather get a bit of gen from someone who has got more knowledge than risk letting it go bang!
  • mmartell
    • Oct 2013
    • 3189
    Re: LG PDP42 goes dim after a few minutes since new ZSUS IPM
    Sounds like your new ipm may be failing open already so yes you will need another one.
    • jesterace
      • Aug 2013
      • 87
      Just started probing the board for shorts and yep, SUS_OUT and VS are now direct short to GND. I guess the last time it went dim it must have took it's last breath, Fuse has gone open too.
      Do you think i got a bad IPM considering it worked for a well over 10 minutes initially or might there be some serious problems with the board?
      • mmartell
        • Oct 2013
        • 3189
        Those ipm's are a crapshoot because most are "pulls" - no telling where they are at in their life cycle. There's probably nothing wrong with your zsus board but wouldn't hurt to check the 5v and 18v lines for excess ripple.
          Most likely you got a bad IPM.
          • mecha1166
            Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
            by mecha1166
            I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
            07-03-2024, 05:03 PM
          • waigy
            HDD stops after about 2 minutes
            by waigy
            Seagate barracuda compute 6TB 3.5 inch drive.
            When I power on my pc, at 1 minute 20 seconds I am into windows and I can see and access this drive.
            But only for 20 seconds then it will freeze and disappear from my system.
            So it won't be in device manager or computer management/storage.
            I've tried lots of different hard drive software that runs from a usb boot stick and the same happens there.
            The drive is only available for less than 2 minutes then it's gone.
            Same in the bios, it shows when first opening the bios, but if I exit the bios then go...
            10-26-2023, 08:38 PM
          • aaronkatrini
            DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
            by aaronkatrini
            I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
            - Put the card in my testing motherboard and start running Heaven benchmark
            - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
            - Try to start it again and I get a slight move from the PSU fan - a clear short
            - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
            - Put the...
            05-18-2025, 04:18 PM
          • ictc
            Lenovo IdeaPad S145 boot when cold than crash after feew minutes
            by ictc
            I received this laptop, which initially boots into Windows normally, but after a few minutes, the system freezes with no display and no response except for power button. When this happens, power consumption rises to about 1A (without the battery connected), and the CPU becomes noticeably hotter compared to when the machine is operating normally.
            I have already tried removing the additional RAM module, which initially showed some promise, but the issue persisted after a reboot. I also attempted replacing the BIOS, but this did not resolve the problem.
            When the system crashes,...
            01-31-2025, 11:29 AM
          • Newmultifail
            Asus g750jx Bios turns off after 30 minutes
            by Newmultifail
            I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
            I should mention that the bios update did not help.
            backup i sn...
            I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
            12-19-2024, 03:41 PM
