LG50PC1D Plasma PSU Power up procedure.
  • nogger
    • Aug 2010
    • 190
    Hi all
    Just wondered if anyone had the procedure for bench testing this PSU for bringing up the output voltages in the correct sequence.
    Procedure i have used so far is:
    I get 5.3v standby & 4.8v on the AC detect pin.
    Linking the Stby volts to RELAY ON i get all the secondary voltages (except 3.3 & Va/Vs) Again linking Stdby volts to the 3.3v_ON i get the 3.3v, so far so good.
    Next i linked the Stby volts to the M5V_ON i get the 5 volts.
    If i now link VS_ON to 5volts Va & Vs momentarily kick in before the relay drops out so not sure if i am testing in the correct sequence or if i have a VS/VA fault.
    The original complaint from the owner wasjust set would come on but takingb longer &longer whichi attributed to the failing output caps.
    Graham
    Re: LG50PC1D Plasma PSU Power up procedure.
    On these supplies Vs needs to be loaded or it will go up to about 220V then shut down due to over-voltage protect. A 60W or 100W, 230V light bulb works well.
    • nogger
      • Aug 2010
      • 190
      Thanks Tom,thats exactly the kind of info that i was looking for. I will give it a bash now & report back.
      • nogger
        • Aug 2010
        • 190
        Tom that's spot on, works a treat.
        Thanks for your help
        Graham
        • u666sa
          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
          by u666sa
          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
          Platform: ipa32 la-m024p rev 1b
          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
          I found a short on the other side:
          10-04-2025, 05:03 PM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • supermattch
          HP 15dy-2021nr wont power on mystery volts
          by supermattch
          Hi everyone.
          I am diagnosing my personal laptop, because it wont power on and no leds light up.
          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
          09-23-2025, 12:13 PM
        • MisterAIL
          PS5 digital / No Power / No Beep / Good power supply
          by MisterAIL
          Brought a non functionnal PS5. Apparently only a bad PSU...
          No beep, nothing.
          After some tests i found this :
          - PSU is fine (12 volts stable)
          - 12 volts line is shorted
          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
          - By the way, nothing change. No signal, no power, no beep.
          Mesuring all rails with my workbench psu (12 volts input)
          - 0.00 amp drawing
          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
          03-12-2024, 03:24 PM
        • Mcfeetroy
          Fishing bite alarm drains battery
          by Mcfeetroy
          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
          08-01-2025, 03:52 AM
