Mitsubishi WD-82837 Software
  • Electron4444
    The fixer Guy
    • Jun 2014
    • 12
    I Have a Mitsubishi wd-82837 with software version V41+_11_01. There are two later versions of software available for this TV. V41+_11_02 & V41+_11_03.
    I would like to know if anyone knew what are the purposes of these software updates and what changes after they are installed.
    The Mitsubishi web site doesn't give any info on these updates.
  • nuala
    • Aug 2013
    • 37
    Re: Mitsubishi WD-82837 Software
    If I were you I would do the software V41+_11_03. It could be that the software update will take care of the problem your having. Make sure you format the stick to FAT32 before you down load the software to the stick.
      Copy DMI info easily with Hex editing software and Macro script
      by SMDFlea
      Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
      Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
      02-28-2023, 02:14 PM
    • NeedsPractice
      Backup To OneDrive Software? Everything! Best Software?
      by NeedsPractice
      I contacted Microsoft and they said they do not have software to where you could backup all your files to one drive. I mean you can copy some of your files to your one drive folder and back stuff up. However, it does not do this automatically.
      I have around (10) hard drives I want to backup to the cloud with One Drive. What is the best software to do this with?
      AOMEI Backupper
      I Drive
      Easeus
      I do not want a Cloud Plan. I just need the software to take my DATA and Transfer it to the cloud in a nice, readable, viewable fashion. I wish...
      02-04-2022, 06:04 PM
    • BMCappelletti
      iMac fan ramps up after shutting down. Software? SMC? FET?
      by BMCappelletti
      Hi everyone.
      There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
      In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
      It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
      At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC...
      01-17-2025, 08:11 AM
    • Russ17
      JVC LT-55C870(B) Corrupt Software??
      by Russ17
      I have a JVC LT-55C870(C). All that happens upon applying power is the red led flashes slowly (1Hz).
      If I hold the OK on the remote while powering on, the led flashes at 2Hz, but without a USB Device attached, it obviously does nothing, no screen or backlight.
      Any thoughts on this being corrupted software?
      Owner says the TV experienced a power surge.
      If software is a possibility, can someone point me in the right direction to download the correct software. Is there a procedure to force software to load from USB?
      10-10-2023, 12:34 PM
    • howardc64
      Vizio SmartCast TV software bug that looks like hardware
      by howardc64
      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
      11-16-2024, 05:17 PM
