37" technika lcd37-207 cycling red,green blue
  • elviramjw
    • Apr 2013
    • 56
    I have a 37" technika lcd37-207
    Main board is vestel 17mb12-2
    PSU is 17pw20-1
    all voltages are fine & no bulged caps
    How ever, when it powers up it cycles red,green then blue, repeating.
    seems like its in some sort of test mode.
    Is any one aware of such a test mode and if so how to exit from it.
    There is no access to menus or av source selection
    any suggestions?
    E
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: 37" technika lcd37-207 cycling red,green blue
    Wait for Tom he loves Vestel sets! LOL
    Sounds like a test pattern loop but I certainly haven't seen a test pattern option on any vestel boards before. Most likely a bad Main
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Thats a corrupt epprom seen it before, beat Tom to it lol !
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        The epprom is a little 8 pin o the mobo will look something like this:
        You can simplify buy a blank one and install it.
        • elviramjw
          • Apr 2013
          • 56
          thnx for the info
          i can probably program one, does any one have the bin/hex file for this model
          E
          • elviramjw
            • Apr 2013
            • 56
            r u saying a blank one will make it work i.e. erase it?? - or replace it as it may be faulty?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Literally just a blank epprom of the same type will work on these sets.
                Really almost any compatible EEPROM will work, I have borrowed one off a different Vestel set stuck it in, all settings were wrong but did a factory reset and changed the defaults where appropriate (have to set, e.g. the number of HDMI and SCART inputs, type of tuner, type of LCD panel...)
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  These main board arent actually that bad rearly see them fail apart from epprom and bad start up resistor too bad the psu is a pso.
                  • elviramjw
                    • Apr 2013
                    • 56
                    Fixed....
                    did a bit of googeling after your eeprom comments, procedure was as follows
                    1. powered up tv and removed eeprom (on socket) as quick as i could, then waited 30 sec.
                    2. reinserted eeprom (this was the old one) whilst powered up then waited 30 secs.
                    3. powered down, then up. every thing was OK
                    did'nt even have to go into service menu to reset av inputs
                    thnx
                    guys n gals
                    Big E
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Good stuff also consider recapping the psu, when ever I get these 17pw20's I fully recap the including the poll caps above the transformer, they are ticking time bombs. Here is one I did a few days ago.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Ive had a couple of these do this....
                        Easy way out is turn set on--its flashing through colours--Obtain the correct 'Service-Mode' code for that mainboard, Enter via remote and the 'fault' clears.
                        No need for messing with EEPROMS.
                        --Whats all this with those 'Poly' caps by the heatsink then? I must have done several hundred of these--NEVER had any issues with those caps!
                        Intermittent shut-down is dry-joints on the three diagonal SM resistors--Not those caps....
                        TELEFIX
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Basically the early 17pw20 v1 which had the red type of polyls they tended to fail causing lots of issues like intermittent power ect.
                          • elviramjw
                            • Apr 2013
                            • 56
                            didnt have remote - but have URC's. will try next time i get one like this
                            • Techstar
                              Tv Restoration
                              • Dec 2012
                              • 122
                              • United Kingdom.
                              PSU is 17pw20-1
                              any suggestions?
                              E
                              I had this fault on a goodmans lcd tv , the cure was to press menu on the remote control then 4725 , fault vanished..
