Samsung LN46C600F3FXZA - No backlight
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    I'm working on this Samsung L46C600F3F LCD which works, but isn't lighting up the backlight. Does anyone know of a good place to start troubleshooting this? Would the readings from the connector described in this other thread be a good place for me to start?
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LN46C600F3FXZA - No backlight
    Does the power supply get the BL-ON signal from the mainboard?
    Upload some pics.
    • SurrealMustard
      • Jan 2015
      • 487
      Measurements
      Upload some pics.
      I'm not completely sure. Here's what I've got for measurements from the connection between the power supply and the mainboard (most of these look to be on par with the little chart, as pictured):
      1. 12v
      2. 0
      3. 12v
      4. 5v
      5. 5v
      6. 5v
      7. 5v
      8-11. Ground
      12. 1v
      13. 12v
      14. 1v
      15. 12v
      16. 5v
      17. 12v
      18. 0
      If it helps, I also measured the CN1802, which connects the power supply to the inverter. I got 12v on pin 1 and 9v on pins 6 and 7. Turning on the power with the mainboard disconnected from the power supply (as suggested in the other LN46C600F4FXZA thread) does not elicit a response either.
        You need to put the name of the next to the pin number so we will know what each pin is.
        That thread in the link you post is a good thread to follow, since that cap is the commonly failed cap I would check its capacitance, or see if it has bulging to the side.
        • SurrealMustard
          • Jan 2015
          • 487
          Results with definitions
          Here are the voltages with the pin names, going by the printout on the board next to the connector:
          1 (B18VS). 12v
          2 (SW_POWER). 0v
          3 (B18VS). 12v
          4 (A5V). 5v
          5 (B5V). 5v
          6 (B5V). 5v
          7 (B5V). 5v
          8 - 11 (GND). Ground
          12 (FRC_HSYNC). 1v
          13 (B13V). 12v
          14 (PWM_DIMMING). 1v
          15 (B13V). 12v
          16 (SW_INVERTER). 5v
          17 (B13V). 12v
          18 (DET_5V). 0
          I don't have a tool with which to do capacitor testing and they all look fine to me. Would the inverter be a possible culprit as well or should I focus more on the power supply board?
            OK, your pinout and the names are way off as printed on the board (BN44-00341B).
            I.E.
            Pin 1 = B13V
            Pin 2 = LAMP_DET
            BTW, the exposed pins on the top side are the ODD NUMBER pin, the EVEN NUMBER PINS are on the bottom side of the board. The white triangle is pin 1.
            POST 3
            1. 12v
            2. 0
            3. 12v
            4. 5v
            5. 5v
            6. 5v
            7. 5v
            8-11. Ground
            12. 1v
            13. 12v
            14. 1v
            15. 12v
            16. 5v
            17. 12v
            18. 0
            Post 5:
            1 (B18VS). 12v
            2 (SW_POWER). 0v
            3 (B18VS). 12v
            4 (A5V). 5v
            5 (B5V). 5v
            6 (B5V). 5v
            7 (B5V). 5v
            12 (FRC_HSYNC). 1v
            13 (B13V). 12v
            15 (B13V). 12v
            17 (B13V). 12v
            18 (DET_5V). 0
            • SurrealMustard
              • Jan 2015
              • 487
              I see
              I.E.
              Pin 1 = B13V
              Pin 2 = LAMP_DET
              POST 3
              1. 12v
              2. 0
              3. 12v
              4. 5v
              5. 5v
              6. 5v
              7. 5v
              8-11. Ground
              12. 1v
              13. 12v
              14. 1v
              15. 12v
              16. 5v
              17. 12v
              18. 0
              Post 5:
              1 (B18VS). 12v
              2 (SW_POWER). 0v
              3 (B18VS). 12v
              4 (A5V). 5v
              5 (B5V). 5v
              6 (B5V). 5v
              7 (B5V). 5v
              12 (FRC_HSYNC). 1v
              13 (B13V). 12v
              15 (B13V). 12v
              17 (B13V). 12v
              18 (DET_5V). 0
              You know, I was looking at that and thought I had them the right way, but that was apparently not the case.
              Given that we've figured out the correct values now, do you think are they on the right track for what the power supply should be putting out? All the names that have numbers in them closely match the actual voltage, so am I right in my assumption that everything on the power supply looks okay based on this? Would the inverter board be the more likely culprit?
                No, that readings with the name and pin numbers are wrong.
                For example, pin 18 of the board is PWR-ON/OFF, you show pin 18 reading of 0V, that means the PS-ON is not present to turn on the power supply board.
                Pin 7 you show that it has 5V which will be impossible since pin 7 is GND,
                PIN 7, 9, 10, 12 are ground pin. You have "8 - 11 (GND). Ground"
                You should take the Voltage readings again with correct pin names and numbers.
                Without correct readings then we cannot tell what is going on.
                • SurrealMustard
                  • Jan 2015
                  • 487
                  Fixed
                  As suspected, the power supply was indeed the culprit.
                  Fixed!
                  • Ierwin
                    by Ierwin
                    05-13-2025, 03:31 PM
                  • triplefour
                    by triplefour
                    09-13-2023, 10:43 PM
                    09-07-2024, 05:50 AM
                  • Jembang
                    coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                    by Jembang
                    good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                    11-01-2024, 09:55 AM
