Samsung LN46C600F3FXZA No backlight
  • 1997eclipsegst
    • Feb 2013
    • 99
    • US
    Hi everyone,
    I am working on this set I picked up off Craigslist.
    When I turn it on I get the normal Samsung chime but the backlights never come on. I can take a flashlight to the panel and see snow being displayed on a channel with no signal. If I hook up my cable line I get sound as well.
    A couple things I have tried already:
    Unplugged the mainboard from the power supply to see if the backlights would come on. No difference.
    I read on the forums that the JP852 jumper may cause the backlight to flicker and that it should be cut, which I did with no change.
    Voltage readings from plug JP824 from mainboard to power supply:
    1- B13 12.31vdc
    2- Lampdet 0.00vdc
    3- B13 12.31vdc
    4- Sw Inv 5.14vdc
    5- B13 12.31vdc
    6- Pwm_Dim 1.66vdc
    7- Gnd
    8- H_Sync 1.67vdc
    9- Gnd
    10- Gnd
    11- B5v 5.15vdc
    12- Gnd
    13- B5v 5.15vdc
    14- B5v 5.15vdc
    15- 18vs 12.31vdc
    16- A5v 5.16vdc
    17- 13/18vs 12.31vdc
    18- Pow_on/off .88vdc
    Voltage readings from plug CN1802 from power supply to inverter
    1- 12v 12.23vdc
    2- FB 0.00vdc
    3- FB 0.00vdc
    4- Gnd
    5- Gnd
    6- LD 8.94vdc
    7- LD 8.94vdc
    I have checked the fuses on the power supply and both are good.
    Voltage across the large 450v caps is 390vdc on each
    Anyone have any ideas what to check next?
    Thanks in advance!
    Re: Samsung LN46C600F3FXZA No backlight
    "18- Pow_on/off .88vdc" This voltage should be 2.5V or more when power switch is activated. So far the power supply/inverter board is getting the correct signals from the main board. SCH for the BN44-00341B.
    • 1997eclipsegst
      • Feb 2013
      • 99
      • US
      Hi Budm
      Thanks for the reply and schematic
      I just went and double checked pin 18- Pow_on/off and it reads 0.00vdc when the set is off, and when the power button is pressed it will change to .88vdc and nothing higher.
        I need to look at the SCH, but it is enough to turn on the PFC and the power supply, otherwise you will not be getting the 390VDC.
        OK, 0.8V is correct, that the Vf of B-E of QM805 + small voltage drop on RM838 (220 Ohms).
        This power supply-inverter board combo has built-in pull-up resistors for the PS_ON and the BL_ON, so if you disconnect the main cable between this board and the main board, the backlights should come on the minute you plug the TV into the Outlet.\
        Fuse FS802S which is for the inverter circuit is OK?
        • 1997eclipsegst
          • Feb 2013
          • 99
          • US
          With the cable disconnected between the power supply and mainboard I plugged the power supply in and get nothing from the backlights, not even a flicker.
          I checked Fuse FS802S and reads 307vdc on each side of the fuse
            That should read 390Vdc since it goes back to the 450VDC filter caps, please see the SCH.
            By the way, we are checking the voltage in the primary side of the circuit, so the negative leg of the 450Vdc cap is the primary side Ground ref.
            • 1997eclipsegst
              • Feb 2013
              • 99
              • US
              Budm,
              Testing off the negative leg of the 450Vdc cap fuse FS802s reads 390vdc on each side. I originally was testing with the ground probe on one of the grounding screws of the power supply.
              • Zalinar
                Zalinar
                • Sep 2012
                • 10
                Hi, I just thought I would throw in my two cents. I have the exact same set with the exact same problem. After replacing the inverter controller IC, which was NOT the problem, I found that C1818 on the power supply had gone bad. It read full open and registered no ESR. I replaced it and am good to go! It is just a .47uF 1Kv block style film capacitor.
                Hope this helps someone who might have the same problem!
                  OK, now we know that the PFC voltage booster is OK and working as it should, so next thing will be testing that DC blocking cap C1818 as mention above, verify it is still show 0.47uF on your cap meter, that is one of the commonly failure cap.
                  If it is bad, it should be replaced with high impulse current type poly film cap.
                  • Zalinar
                    Zalinar
                    • Sep 2012
                    • 10
                    Thanks Bud,
                    I intended to post here some time ago since I have the same TV with the same problem, but didn't want to Hijack the post. I hope I am not...
                    It seemed that the original poster abandoned this thread some time ago.
                    _______
                    So, after a long day yesterday, I accidentally replaced the capacitor in my good power supply that already worked. I got excited prematurely.
                    I replaced the same C1818 cap in my bad supply, and now the back lights only flash on for a split second and then shut off again. I guess that is a step forward since they didn't come on at all before. Any ideas are welcome and I can tinker with it after work this evening.
                    Thank you very much!
                    • jugador87
                      • Jan 2014
                      • 3
                      • Chari
                      Zalinar, I've got the same issue. Still need to go get a multimeter to test out the pins. Did you ever resolve your issue?
                        Zalinar fixed his board, it has bad C1818 (0.47uF 1000V).
                        • Zalinar
                          Zalinar
                          • Sep 2012
                          • 10
                          Actually, no. As I said in my November post (which must have looked like a signature file since I got no replies), replacing the capacitor only made the back lights flash on for a second which was a step forward from them doing nothing. There was still something else wrong.
                          I ended up purchasing another board since I didn't know what to replace next.
                            Oops, I missed that follow-up.
                            • jugador87
                              • Jan 2014
                              • 3
                              • Chari
                              Yup, that's what I thought I read. So replacing the board worked? I have replaced my power supply board (albeit from eBay, the only source I can find anymore), with no change. I also replaced the mainboard, with the same result.
                              Thankfully I have a multimeter and some time this weekend. Any objection to hijacking the thread? Or should I just start a new one?
                                • 31187
                                what's on that long board under the black cover on the right?
                                • jugador87
                                  • Jan 2014
                                  • 3
                                  • Chari
                                  That would be the inverter board. I replaced that one as well.
                                  I should add that all parts were sourced from eBay, so quality is suspect.
                                  • efren hernandez
                                    • Oct 2012
                                    • 2
                                    • usa
                                    I had the same sound and image problem but no backlight what solved it by removing the bridge jp852
                                    • joellamoreaux2
                                      • Jan 2016
                                      • 1
                                      Hey guys I am new to the site as a member but have been using the site for a while. Did anyone get the backlight to work after Replacing the C1818 Box style Cap and cutting JP852?
                                      • mradamrada
                                        • Jun 2016
                                        • 1
                                        • united states
                                        Does anyone know what the FB pin is for?
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-X01DE boardview and NP950QCG-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
