Samsung LE40B530P7W won't power up - Red LED flashes 5 times
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Samsung LE40B530P7W won't power up - Red LED flashes 5 times
is there a part number on the transformers? we maybe able too get a data sheet and see what the winding resistance should beComment
What is the board P/N? BN44-???????Never stop learning
We need good clear picture of the bottom side of the baord so we can tell you which pins are for the HV windings.
Here is the schematic so you can see the pinout of the transformer.
Pictures provided by shopjimmy.
BTW, the meter is showing in OHM, K OHM, M OHM?Last edited by budm; 08-16-2017, 09:12 AM.Never stop learning
See post 29.Never stop learning
meter set to ohmComment
What is the P/N of the one on the right which is not the same as the other 3?Never stop learning
http://store.lcdparts.net/3324340028...4T_p_3866.html
About 1000 Ohms. They should be about 3% from each other.
http://store.lcdparts.net/3324340029...4T_p_3865.html
About 680 OhmsNever stop learning
About 680 Ohms
1k and 680 , i guess they are fine
yet im back to square one... can't figure what's wrongComment
so what symptoms do you get when you first turn on the tvComment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by mrtekHi
Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
Main fuse = OK
Back light LED = OK. Power them with aux power source
LED output = OK 156V
I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on... -
by dicky96Hi guys
I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time... - Loading...
