Element elefw502 firmware issue
  • Gadjet
    • Aug 2012
    • 248
    Anybody know where I can download the firmware for this model? TV originally wouldn't power on change the mainboad it powers on but the controls aren't right using the panel or the remote. power turns on the power, vol. buttons go to the menu selections, chan. buttons change the vol., menu button changes inputs. Ordered another board same thing. So now I'm looking for the firmware.
  • nuala
    • Aug 2013
    • 37
    Re: Element elefw502 firmware issue
    Element: http://www.elementelectronics.com/support/
    • Gadjet
      • Aug 2012
      • 248
      Under the model number of the tv the only downloads are the pdf's for the manual, warranty and quick start card.
      • nuala
        • Aug 2013
        • 37
        Sorry, someone gave me it and said it had firmware updates.
        • titomno2
          Surface Pro 7 type 1866 PD controller firmware issue
          by titomno2
          Hi guys,
          Hope you are fine.
          I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
          The boot time is so long (up to 5-10 minutes).
          After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
          I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
          In the past I have found that if the update is a success, the boot...
          04-27-2025, 01:02 AM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • wattage
          by wattage
          Hello Badcaps Community,
          07-13-2025, 04:41 PM
        • tsitsos
          43 inch tv firmware issue.The board is cv338h-t42
          by tsitsos
          Hello all. I would like some help on installing a firmware on tv..
          4 days ago i changed a channel and the image became complete blue and the tv unresponsive. No matter what i did ( like unplugging the power , press the power button for minutes etc etc nothing helped) Then i had an idea to flash it via usb. The brand is very uncommon (smarttech) so i had hard time finding the right firmware. i ended downloading 2 just in case. I flashed the first one with usb and pressing the power button like 5 times. The installation was successful and tv worked ok with some little problems that right...
          03-11-2022, 07:32 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
