Samsung LN-T4671F : need help display corruption / RGB lines
  • enc2guru
    • Jul 2013
    • 6
    Any information on the issues seen in the photos would be helpful, tried reseating LVDS with no change, this issues does effect the border of the OSD and i found out it is input independent as changing the no input signal screen to "BLUE" it will develop these lines. I did notice that it wont be quite as bad if i don't activate the OSD box and when I do the thicker bars seen in the black verizon screen will appear and stay after exiting the OSD and the white dots/lines in pattern on the top of the screen are a new one for me? I would like to fix the issue myself, I work on a lot of electronics but when it comes to display issues I'd rather ask than jump into anything myself.
    Thanks any and all help will be appreciated.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung LN-T4671F : need help display corruption / RGB lines
    Does the picture improve the longer the set is on?
    TELEFIX
    • enc2guru
      • Jul 2013
      • 6
      I had it on for about 90 minutes and it did not get better. If i turn it on to the cable tuner "snowey screen" there is no corruption. If i leave it on the black screen with the red Verizon it shows the lines as seen and wont get worse. When I tune to a channel the colored lines appear and do not go away. I don't know if 90 minutes is enough time where it would improve or not.
      • Shinju
        • Mar 2014
        • 1239
        Service mode and run test patterns.
          09-07-2024, 05:50 AM
        • Rubenlily
          Samsung QE50Q67TAU - horizontal lines
          by Rubenlily
          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
          I'm no expert but I've done the tape...
          08-16-2023, 01:12 PM
        • jeyoung12
          Samsung QN50Q60t lines on screen
          by jeyoung12
          Hi all
          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
          So....i don't know what end of the C ribbon to work with...
          02-26-2024, 10:38 AM
          09-06-2024, 11:40 PM
