Panasonic TH-50PZ81B
+ More Options
Posts
  • vaxthehunted
    • Apr 2015
    • 11
    • scotland
    Hi There,
    I'm looking for a bit of assistance on a Panasonic TH-50PZ81B. It is the first plasma tv ive worked on and is causing me a bit of grief.
    the problem is once turned on it starts up ,fans run, and display works but after around 10 - 15 seconds it shuts down and i get 12 flashes from the power indicator.
    i was reading a different post from a while back and it confused me a bit as this is a sound sos error and things led to the a board then the p board.
    just a bit confused and would appreciate some assistance.
    thanks
    David
  • datylor992
    • Oct 2014
    • 13
    • Trinidad
    Re: Panasonic TH-50PZ81B
    It seems that you may have a faulty signal PCB.
    Disconnect the Fan PCB and see if the set remain on for more than 15 mins.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Disconnecting the fan-pcb will lead to a different SOS (5?) and no start-up.
      TELEFIX
      • vaxthehunted
        • Apr 2015
        • 11
        • scotland
        thanks for getting back to me,
        i have tried dissconnecting the x and y (just to check them) they both fed back the relevent sos flashes , the trouble is i checked the speakers and main board they seem fine have not yet tested the power board (due to dropping multimeter down around 10 solid stairs and smashing it.) surely if it starts and powers up it shouldnt be the power board. im quite possibly very wrong but i am used to nice 3 - 5 board lcd tv repairs.
        • datylor992
          • Oct 2014
          • 13
          • Trinidad
          I have disconnected the Fan PCB in a TH-46PZ85U because when this PCB is plugged in the set is not coming on but giving 11 blinks.
          I have an external fan on the unit and it is operating good but sometimes the picture becomes solarized. I think that my problem is on the Video signal board since this board is common to the TCON PCB and the Fan PCB.
          Could anyone help.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Could anyone help.
            I would say you have a problem on the SC board--One of the sub supplies derived by the DC/DC converter is not stable....
            What picture conditions does it solarise?--Bright scenes?
            How many hours on the set? V-SUS and Vda Correct?
            TELEFIX
            • tw2005
              • Oct 2011
              • 6458
              Have you tried running it with speakers disconnected?
              Also since these have PSU issues with the MC201,301 modules one of which produces the 15V there's a possibility the 15v is dropping out and causing 12 blink in error.
              A long shot but the flow chart for 12 suggests, speakers, A board or 15v issue and follow 2 blink chart which makes me wonder if you should do those modules first?
              While this is apart it'd be worth doing those ceramic caps on those modules.
              • emil_t
                RTX3090 working fine but fans not spinning
                by emil_t
                Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                04-12-2024, 06:54 AM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                11-20-2024, 08:52 PM
              • AquaMan Ua
                Problem with PANASONIC CF53 laptop after changing BIOS settings
                by AquaMan Ua
                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                05-17-2025, 09:40 AM
              • JayPoorJay
                Hot Water Rad - A Few ECU Fans and a Timer Switch
                by JayPoorJay
                Good Afternoon, Good People.
                I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                I REALLY would appreciate y'alls help.
                This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                10-29-2024, 12:54 PM
              • stecos
                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                by stecos
                Hi everyone!
                I happened several times, in the search for help from the web, to consult this very interesting forum.
                So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                Having said that I come to the gist of my post on the forum as the title suggests.
                For my passion for technology I'm now collecting several...
                11-28-2022, 11:39 AM
