Bush a632n
  • gary19610
    • Dec 2012
    • 74
    Bush a632n
    bush a632n from standby I switch tv on blue light on and about a min turns of but blue light is still on till I press standby then red light standby comes back on.so picture for about a min then black screen but blue light still on sounds like back lamps
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bush a632n
    What are you expecting us to say, you have just told us some random information and not asked us any thing lol
    • sordids999
      • May 2013
      • 2156
      Re: Bush a632n
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Tomylee
        Nintendo 2DS XL – Orange light, no blue light, signs of overheating
        by Tomylee
        Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
        Here's what I've observed:
        All ribbon cables are properly connected
        Battery is present and in good condition
        No reaction even with screens disconnected
        There's a visible burn mark / overheating sign on the metal shield, right above the CPU
        I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
        06-26-2025, 02:33 PM
      • AleMonti
        LG 55EG910V - no power and no standby light
        by AleMonti
        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
        After checking the basics I did the following:
        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
        11-04-2024, 05:02 PM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
      • Nicktronic
        Samsung UN70NU6070F Standby Light flashes twice
        by Nicktronic
        Hey Everyone,
        So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
        I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
        03-27-2023, 07:01 PM
