Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
I took out
Transistors labeled 30G123 at locations Q421 Q422 Q423 all tested short
Transistor labeled RJP6065 at location Q661 and it tested short.
After taking it out, my SMDiode D673 and D674 labeled K696 are now working properly.
I have not taken any other transistors or diodes out. However the 6 SMDiodes that I am still registering as bad are the following:
D503
D522
D524
D711
D618 is physically burnt
D865 is located in front of, and is also shorted with D621 and D622 so it more than likely is ok, I just have to take D621 and D622 out of circuit to make sure. However the other 4 diodes were all located near the Q421 Q422 and Q423 that I already took out, and they are still acting weird.
Here are the following readings I get with the SMDiodes in circuit with my DMM on diode setting.
D503 Black on cathode red on anode .348v red on cathode, black on anode .353v
D522 Black on cathode red on anode .473v red on cathode, black on anode .726v
D524 Black on cathode red on anode .473v red on cathode, black on anode .726v
D711 Black on cathode red on anode .459v red on cathode, black on anode .641v
Back to non surface mounted diodes, I have D401 and D402 registering shorts,
I have Q401 on diode setting registering 0v between the emitter and collector, and .037v between the gate and the emitter and since the emitter is shorted to the collector, I get the same result on the collector. Measuring with both cathode and anode on gate, I am getting .037 both ways. On ohms I am getting 59.1 ohms between gate and emitter/collector.
Q402 right next to it is the same thing except I am getting .044v on diode setting between collector/emitter and the gate, and with ohms I am getting 70.8ohms.
Q403 emitter and collector shorted as well, but is giving me with anode on gate .568v on diode setting, and with cathode on gate, .993v.
In ohms I get about 47Kohms.
So I am not 100 percent sure what the deal is with those, but I am assuming Q403 is good but Q401 and Q402 need replacement.
D641 is showing on diode mode .338v going both ways.
Q601 shorted
Q441 shorted
So far this is what I found. I tried looking at some of the resistors near the transistors that went out, all tested good, I tried testing the IC's but then I realized I had no clue how to and decided to do that tomorrow once i have a chance to look over all of your back and forth replies once more to see how you tested them and what results you got so I can compare from there.
That's where I am right now, but I am going to take it slow and for sure will not plug this thing back in until I have a chance to test every single component on it haha.
However, I was able to find a few of the fets/diodes, and unless I want to pay $10 per component, I need to order from china, so I was hoping to start ordering some of those parts ASAP so I don't have to wait to long.
Also I have 2 of these exact same TV's with similar problems. This is the board that I have found has less problems, the other seems to have way more components that have gone bad, so I wanted to start on the easier one first.
Lastly here are all the locations and part numbers that I have found to be bad or think they are bad.
Driver IC M81707FP IC521 IC501 no clue how to test, but every repair kit has them and it seems like it went bad for you guys as well.
30G123 Q421 Q422 Q423
45G127 Q441
RFUS20-TM6S D401 D402
2pg011 Q401 Q402 Q403 these I am not 100 percent if all bad or if q403 is good
RF2001-TM3SW D621 D622 D641
RJK6026 Q601
RJP3034 Q621 Q622
RJP6065 Q661
Let me know what you think.
Thanks for taking the time to even read all of this, I know it's very confusing the way I presented it, I barely understand it when it's all separated out, but I have no idea how to properly organize it and what is connected together.
Thanks again
I am currently attempting to repair my board, TNPA4782ab and I found that a lot of the components you talked about were also faulty on my board as I followed the same measurements as you showed in previous replies. However, I don't usually do many board repairs unless its basic Diodes caps, and or certain surface mounted components such as EEPROM chips, or fuses.
Because of the above statement, I have no idea where to buy these spare surface mounted diodes, IC's and or transistors. A few of the IC's I was able to find on ebay, but some of the transistors when typed in show up with a few different options. For example, RJK6026, I get RJK6026 and RJK6026DPP. What does the DPP at the end mean, and is there a difference? If so, which would I need?
Also I have no clue where to buy the surface mounted diodes. I have about 8 of them registering shorts, and the only symbols on them are K696 for 4 of them and the other 4 say 8897.
Thanks for the help.
As for the diodes, a little suprised you have not correlated 8897 which is actually marking 88 as the same as D618 mentioned in previous posts.
That also means K696 is in fact marking K6 made by Shingenden.
before you rush off and start getting bits, I'd remove the suspected shorted IGBTs first. then recheck the diodes, i suspect the K6 you refer to are in front of Q661/660.
Watch out for open cct pcb tracks where ever there is evidence of burning.
You could try UTSOURCE (will take weeks to arrive)or a kit but not just any kit. get a list together of what you find.
8 diodes sounds more than what i found but there's a number of ways these can fail I suspect. I would be more specifc with the info like exact locations.
i've only done 2 and only a small amount of info shared on self repair here.Leave a comment:
Thanks for the help.Leave a comment:
Picked up a broken Rev AC 46" board. virtually no diiference between this and an AB 50" (G10) except placement of the inductors and a couple of caps.
Q601, RJK6026 shorted
Q661, RJP6065, shorted
Q441, 45G127 shorted
Q451, 45G127 _ shorted but not the same as 441, I suspect that when 441 is out this may be ok
Q701, MMBTA92 blown out
Q702, 2PD601 blown out
Q818, 2SK3018 could be ok
Q604 2SJ281 no short but i'm unsure still what they should do in cct. Not cracked apart like the last one
Q551 CPH5524_ shorted
D608, MA8120M, MAZ81200ML 12V 150mW zener(DIODE ZENER 12V 150MW SMINI2) _ open cct
D618 RF101L4S 400V 1A blown apart
R613 47K reads ok but burnt.
IC771 showing short O/P , 724,725 78L05 _ seem ok
IC773(bad),564 ok, 464,465 suspect_ TC7SH14F
IC521 M81707FP blown out
R521,522 100ohm 5% metal _ visually look ok but R521 is high at 108ohms, R522 appears open at 5.6K so both will need replacing.
IC561,562 appear to have not been shorted this time
New for me , opto PC601 has exploded
Usual scorched tracks
Of the 3 inverter ICs 773,464,465. 464 on this occasion had 3.3ohms vcc-gnd. normally 773. all 3 are on the same 5v rail IC771Leave a comment:
Usual scorched tracksLast edited by tw2005; 05-01-2015, 01:40 AM.Leave a comment:
My 2SJ281 P-FETs (10) just arrived from Poland. 2.49GBP + ship. took 3 weeks from order date to Australia. Works out at $1.30 ea for me.
HFO Elektronik
http://www.ebay.com.au/itm/261478252...%3AMEBIDX%3AITLeave a comment:
second picture is from SJLeave a comment:
Maybe Tom, --Could it be that issue concerning the ERC Cap circuit being fully discharged at turn-on, demanding twice the normal current (Or thereabouts) to flow through the SUS_Up pair--which eventually say--sod it and go short, taking the SUS_Dn pair out and whatever else happens to be around at the same time....?
Just recalling something you mentioned a while back....
This 50G10B has been fine now for two days, --Dunno why it had those SOS7 and SOS4 codes logged....Last edited by Alastair E; 04-14-2015, 09:19 AM.Leave a comment:
I suspect that the 2011's would be fine with the heatsink-free boards but there's a software or hardware design flaw that causes them to fail early. Thermally speaking the transistors only run warm to the touch.Leave a comment:
For sure, i think the PZ series are solid enough bar the PSU. I must admit I like the 2011 panels now I've seen them , the 2 I've done I'm happy with just transistor replacements, at least we know how to fix these cheap, not good for the average consumer I guessLeave a comment:
Well--Not certain models for sure!
The older series like the TH-p42/50/PX/PZ/70/80/81 series are brilliant long lived reliable sets.
--Just a shame they double as room-heaters!Leave a comment:
maybe something like this but it's a pack of 5 so over 20GBP
http://uk.rs-online.com/web/c/?sra=o...hTerm=flux+pen
http://uk.rs-online.com/web/p/solder-fluxes/2513637/Leave a comment:
cool thanks i have most of the stuff already minus flux pen (have you got a link which one you use) also need a jewlers loupe they always come in handy i guess cheers again.Leave a comment:
Oh, I should mention FLUX, flux pen, makes a world of difference and flows so nice which is what you need to avoids bridges.Leave a comment:
Thanks for the information.Leave a comment:
Just read this post from start to finish a good fix and some good info on test procedures etc whats the rough cost for the parts per board? compared to a good used one? Not everyone maybe able to complete this fix i guess due to small parts (smd)?.Can this repair be carried out with just a soldering iron or do you need hot air station? cheers for any advice you can offer. I havnt got a board needing repair but having this info in advance is always handy for myself and maybe other members.
I think anyone who has hot air and experience may do a better job.
maybe one day I'll get a cheap Hot air station and have a go
Cutting the pins makes it easy and I think once you've done a few for what these parts cost better to just replace and treat these drivers as suspect but I must admit with so litle blown on my first 4782 I got lazy and skipped it.
Going to depend on how much is blown as i've read a lot more IGBTs need replacing so plenty of scope for these to be hard.
sometimes you just have to have a go to learn and not give up if possible.
I would say about $20, going to depend on where you get the bits, qty purchased and you'd be mad not to get extras just in case so the first board may need a $40 investment.
looking at the time and possibility of failure, what people charge is probably cheap really for the effort but the more boards you do the more knowledge and more efficient you get.
I think it's fun but lets face it if nobody tried then there'd be a lot of tvs not repairable due to no boards available and buffers are a concern now. i keep all the dead boards just in case and for learning. I'd like to have a go at buffer rebuilds but too expensive for the panasonics i feel and I think hot air would be a safer option.
looking at these 4788,89 buffers, 8 Ics, about $50-60 AUD and you only need to stuff one track up and it's all over, very risky for me at least.
Both of the boards i killed all 8 ics have 1 shorted pinLast edited by tw2005; 04-13-2015, 06:52 AM.Leave a comment:
Just read this post from start to finish a good fix and some good info on test procedures etc whats the rough cost for the parts per board? compared to a good used one? Not everyone maybe able to complete this fix i guess due to small parts (smd)?.Can this repair be carried out with just a soldering iron or do you need hot air station? cheers for any advice you can offer. I havnt got a board needing repair but having this info in advance is always handy for myself and maybe other members.Leave a comment:
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible â so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... -
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by UserrrnameđđģI recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...07-19-2025, 07:53 AM
- Loading...
