TH-P50G15A - 6 Blinks- Bad TNPA4782
  • tw2005
    replied
    Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
    Pin 1 is NC. Well that's pretty rough. Do you have flux pen and a very fine conical tip?
    We seem to be heading off in tangents now. I'm still curious about the OL across the diode
  • Glitcher
    replied
    Just tested PC601 out and changed it, doesn't seem to change my readings for D608 though. I was trying to replaced some extra parts IC464, IC465 near the M81707 FET drivers to be safe but ended up peeling these traces off... Barely even touched it with my iron and it came right off for both of them too! it doesn't seem like the trace goes anywhere, are they just place holders?
  • tw2005
    replied
    Try opto PC601, they're pretty common on sc,ss boards if you have scraps
  • Glitcher
    replied
    Even with the FET removed I'm still not getting the same readings as you. I'm thinking theres a problem somewhere in the area where D608 is. My D608 reads .707 and OL
  • tw2005
    replied
    Actually, i was being sarcastic and now i'm not joking but I think this FET is shot. the whole casing is cracked that's why that leg crumbled out. But this board was working like this except that anomally I discussed with Tom. Which brings me back to these boards working with this part of the cct omitted.
    So maybe get a FET, I am LOL.
  • tw2005
    replied
    Originally posted by Glitcher
    Dang that sucks wait are you getting the same readings on the pads with the fet removed? As in post 53?
    yep little or no difference. you never know but maybe my fet was open ? I actually wanted to test the FET out but that chance is gone
  • tw2005
    replied
    FQD4P25 may be ok not that helps me find one any easier
  • Glitcher
    replied
  • tw2005
    replied
    well game over for my board. just destroyed the Pfet. casing cracked and leg fell out.
    bugger
    Not sure you're on the right track though as i get the same results with the FET out. I don't think you can get more open cct than what i got with no FET at all now!
  • Glitcher
    replied
    Any chance we can start referring to D806 as d608, i keep looking for a diode that does not exist
    Ahh sorry bout that, Don't know why I keep getting them confused. Must be from a past board I worked on.
  • tw2005
    replied
    Did you remove both of those ICs to get the tv to work?
    My D806 was completely blown in half so I had some suspicion the damage could go to that FET. I could be wrong though. I have seen and had some FETs that have completely blown which went open cct but the damage is usually obvious.
    No, that's how that board is from manufacture which is my point. panasonic decided to delete it somewhere along the line. None of the photos at SJ show it deleted but i have one and if you go through Hombre's post he has a 46" board also with no vset cct.
    I have 2 rev AF but hey are not the same. I don't have the other board in front of me just the one with the same setup as yours.
    I'll remove my FEt and see what it does out
  • Glitcher
    replied
  • tw2005
    replied
    have you looked at the pictures I posted of that part of the cct being deleted? I have two AF boards , one with, one without that Vset cct, so clearly it's possible for it to be removed and the Tv to work.
    I suppose I could remove mine and check that P fet. i always thought they'd blow short and FETs need to be switched on to check. I think very early on I did not know this and had a FEt show open but I was testing wrong. Don't kow much about P fets but that one is unique, I tried looking for a sub a while back for a post and never had any luck. Also unique I think for these models.
  • Glitcher
    replied
    Yep, I was also getting OL in cct. This would explain the different readings I got for D806 which is connected to the gate and source of that FET.
  • tw2005
    replied
    Looks like I found the problem, I desoldered it and I'm not getting any readings at all from it seems like it blew. It seems to be a P-Channel 250V 3A Mosfet vg = 30v. Now If I could find a suitable replacement from some of my salvaged Panasonic boards.
    I isolated both R613 and R869 and they measured good.
    so what are you saying , you can't replicate in cct my readings in diode mode?
  • Glitcher
    replied
  • tw2005
    replied
    did you isolate r613 to confirm? also watch out for burn out tracks could be open ccts
  • tw2005
    replied
    Hmm well they ohm out fine now that I replaced them. I was wondering what measurements do you get from Q604? the SMD mosfet next to D806, im having some suspicion on that one.
    blk lead on D, I get is 9.36k G-S, ol on any other
    red lead on D, 2.26Meg D-G, 2.31Meg D-S
  • Glitcher
    replied
  • tw2005
    replied
    Well just tried replacing IC561,562, and 563 and still no avail. What measurement did you get on diode mode for D608?
    answered in post #40 but now with this huge 1watt zener 0.663 & 1.7.
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • EazyBone
    Un50cu7000 2 blink oddity *partially solved
    by EazyBone
    I write this to maybe help another with this TV.
    So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
    The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
    03-18-2024, 10:24 PM
  • Vebririon
    panasonic TX-P50V10E 6 blink led problem
    by Vebririon
    I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
    Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
    I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
    05-17-2025, 10:16 AM
  • Biruslapio
    Panasonic P58V11B 8 and 12 blinks error "fix"
    by Biruslapio
    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
    04-13-2021, 07:13 AM
  • Userrrname
    Tx-pr42gt30 6 blink
    by Userrrname
    👋đŸģI recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
    07-19-2025, 07:53 AM
