TH-P50G15A - 6 Blinks- Bad TNPA4782
  • Glitcher
    • Mar 2013
    • 673
    • USa
    #121
    Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
    Got into the service menu. I went into serv tool and held the return, the tv just resets and brings me back up to the main service menu.
    looks like this set only had 5700 hours on it.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      #122
      TBH--The screws were not slack or any evidence of arcing, I pulled the board just to check.
      No evidence the board has ever seen an Iron --or anything else. If it had been given to me as a brand-new part, I wouldn't have cause to say otherwise, Looks perfect!
      Ive bunged it on the wall anyway--Got fed up with the Cruddy picture on that 4K LG LED set--HATE LCD pictures.....
      TELEFIX
      • tw2005
        • Oct 2011
        • 6458
        I did'nt think you thought much of the panasonic plasmas either?
        • tw2005
          • Oct 2011
          • 6458
          ok, thanks but normally it would restart and turn on like normal TV. maybe the setup is different. I was hoping the missed Pfet on mine may have been the cause of this minor issue.
          You're going to finish this off properly and replace the FET?
          Well we got there in the end, now find another and have another go
          • Glitcher
            • Mar 2013
            • 673
            • USa
            #125
            Yep, and thanks for all the help! Maybe I should start fixing these three 5081 boards I have laying around.
            • tw2005
              • Oct 2011
              • 6458
              Oh, you're kidding you have these laying around! You can fix those easy. How many parts do you have left over?
              • Glitcher
                • Mar 2013
                • 673
                • USa
                #127
                Not much parts left for now. Probably need to order more. Might be hard to fix these since I don't have the panel anymore
                • tw2005
                  • Oct 2011
                  • 6458
                  Here's another way to remove those M81737 Ics, use a precision set of cutters and carefully nip the legs against the casing. Desolder the remnants, use a quality braid like chem-wik to remove all solder , clean with IPA, get some flux or flux pen and prep the pads and legs, tack 2 corners to get it nicely in position and use fine solder and fine tip.
                  • tw2005
                    • Oct 2011
                    • 6458
                    yeah, that would be tricky for testing and you can't plug it in this model either as the Sc20 pinouts are different. You could plug in to a S20, (s2)
                    You'd need RJp63F3a, DG402RP x 2, 30F125 x 2, dg502LW x 2, 45G128 x 1, RFN25TM4SW or a 400v 20A fast rectifier, M81737FP, TC7SH14F, MMBTA92, 2PD601ART, 2sk3018 or 2n7002, RF071L4s or RF101L4s, TA78L05
                    I have done some with only 7 or 8 parts needed but above is fairly normal, CPH5524 would be handy but normally they seem ok,
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      #130
                      I usually use an exacto knife but being careful not to put too much pressure as not to cut the traces underneath. But that's only if I know it's definitely bad. Sometimes I end up wanting to put it back for some reason. I usually put a blob of solder of both ends and heat both ends with my iron until it finally loosens off
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #131
                        Just read this post from start to finish a good fix and some good info on test procedures etc whats the rough cost for the parts per board? compared to a good used one? Not everyone maybe able to complete this fix i guess due to small parts (smd)?.Can this repair be carried out with just a soldering iron or do you need hot air station? cheers for any advice you can offer. I havnt got a board needing repair but having this info in advance is always handy for myself and maybe other members.
                        • tw2005
                          • Oct 2011
                          • 6458
                          I only have the most basic gear, use 2 irons to remove these smaller items heating both sides and use the tips to move them. I have a headband magnifier and a 5x loupe to get a good look at the finer pitch items like those 20 pin octal buffers which are large compared to the 5081 boards. have tried flooding the pins on the FET drivers but mixed results and the heat easily lifts the no connection pads plus very cramped.
                          I think anyone who has hot air and experience may do a better job.
                          maybe one day I'll get a cheap Hot air station and have a go
                          Cutting the pins makes it easy and I think once you've done a few for what these parts cost better to just replace and treat these drivers as suspect but I must admit with so litle blown on my first 4782 I got lazy and skipped it.
                          Going to depend on how much is blown as i've read a lot more IGBTs need replacing so plenty of scope for these to be hard.
                          sometimes you just have to have a go to learn and not give up if possible.
                          I would say about $20, going to depend on where you get the bits, qty purchased and you'd be mad not to get extras just in case so the first board may need a $40 investment.
                          looking at the time and possibility of failure, what people charge is probably cheap really for the effort but the more boards you do the more knowledge and more efficient you get.
                          I think it's fun but lets face it if nobody tried then there'd be a lot of tvs not repairable due to no boards available and buffers are a concern now. i keep all the dead boards just in case and for learning. I'd like to have a go at buffer rebuilds but too expensive for the panasonics i feel and I think hot air would be a safer option.
                          looking at these 4788,89 buffers, 8 Ics, about $50-60 AUD and you only need to stuff one track up and it's all over, very risky for me at least.
                          Both of the boards i killed all 8 ics have 1 shorted pin
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #133
                            Thanks for the information.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Oh, I should mention FLUX, flux pen, makes a world of difference and flows so nice which is what you need to avoids bridges.
                              • tw2005
                                • Oct 2011
                                • 6458
                                my 2 very cheap irons, 20W & 40W with a quality tip in the 40w
                                Also a set of quality fine tip tweezers is handy for handling and placement of the SMD stuff
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #136
                                  cool thanks i have most of the stuff already minus flux pen (have you got a link which one you use) also need a jewlers loupe they always come in handy i guess cheers again.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    No, just a generic flux pen from a local electronic shops Jaycar. Called No clean flux pen. They're not cheap about $12 AUD but for this work I find it invaluable.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      maybe something like this but it's a pack of 5 so over 20GBP
                                      http://uk.rs-online.com/web/c/?sra=o...hTerm=flux+pen
                                      http://uk.rs-online.com/web/p/solder-fluxes/2513637/
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #139
                                        Originally posted by tw2005
                                        Thanks for the rs link i have a branch a short distance from me having five is no problem im sure they will come in handy for other project, im just looking on all my free sites local to see what project tvs are available why pay i say if i can pick them up for just the fuel cost.
                                        • Alastair E
                                          Chief Womble
                                          • Mar 2013
                                          • 1963
                                          • U.K.
                                          #140
                                          Well--Not certain models for sure!
                                          The older series like the TH-p42/50/PX/PZ/70/80/81 series are brilliant long lived reliable sets.
                                          --Just a shame they double as room-heaters!
                                          TELEFIX
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Userrrname
                                            Tx-pr42gt30 6 blink
                                            by Userrrname
                                            👋đŸģI recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
                                            07-19-2025, 07:53 AM
