RCA RLC 4062A screen problem
  • site-web
    • Apr 2015
    • canada
    hello all,
    upper half screen is good
    bottom half screen is bad
    part upside of inverter make a noise bizzzzzz and the part at bottom dont make...
    look at my video. https://youtu.be/Bm3JFrs_Cc4
    thank you
  • Agent24
    I see dead caps
    • Oct 2007
    • 4944
    • New Zealand
    Re: RCA RLC 4062A screen problem
    Something wrong with panel, TCON, or main board.
    -David VanHorn
    • site-web
      • Apr 2015
      • canada
      ok thank you
      • Agent24
        I see dead caps
        • Oct 2007
        • 4944
        • New Zealand
        If you can upload photos of your boards we may be able to spot damaged components and get a better idea of where the fault lies.
        -David VanHorn
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • mmccomputer
          problem with replacing lcd screen
          by mmccomputer
          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
          If anyone has any information on the subject...
          12-15-2024, 03:44 PM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • renech
          panasonic TH-42PC77U plasma television half screen problem
          by renech
          hello,
          I hope someone on this forum can assist me.
          I have a panasonic TH-42PC77U plasma television.
          the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
          i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
          I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
          I have read some posts that suggest the problem is related to the boards on the left...
          12-12-2022, 06:53 PM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
