Vizio Plasma VP50 HDTV20A Won't turn on
  • gingerbreadman
    • Sep 2013
    • 36
    Hi Everyone,
    I recently picked up this Vizio VP50 HDTV20A plasma. The previous owners said one day it wouldn't turn on.
    I hoped it would be a capacitor problem, but I don't see any bulged capacitors.
    When the TV is plugged in it clicks and you can see the backlight in a dark room. All of this happens without the power button. The tv is unresponsive to the power button or any other buttons. The little light on the front stays an orange color. I can't see menus or anything else on the screen.
    I've tried unplugging the x main and ysus boards separately and together but the TV still won't turn on with the power button.
    It has the Samsung panel in it.
    What should I do next?
  • tw2005
    • Oct 2011
    • 6458
    Re: Vizio Plasma VP50 HDTV20A Won't turn on
    There's 2 areas these fail.
    1. the psu, the Vs and Va blow or have cracked joints on the FETs. The long thin heatsink in the middle , check those FETs for short and or bad joints
    2. the more common fail is blown upper buffer board and failed ymain(check the 88N30W and the other FET on the same heatsink shorted)
    UPPER buffers are impossible to find or cheap but i think there are some people offering buffer repair on ebay.
    You'd have to way up the cost of the repair to what this TV is really worth
    • Mulp
      VIZIO M65-C1 Does Not Turn On
      by Mulp
      Hi All,
      I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
      When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
      I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
      01-13-2024, 09:57 PM
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • canadaboy25
      LG 50PJ550 Plasma tries to turn on then turns off
      by canadaboy25
      Hey guys,
      I have a LG 50PJ550 plasma that will not power on.
      When plugged in, the relays click and the screen lights briefly before the relays click again and it shuts right down. It then tries starting up again before giving up and just sits there with the red LED on. Pressing the power button again repeats the process.
      During the moment where the screen is on, there is a slight fuzz that starts to go away as most plasma's do when they turn on. So i do not think it is a panel issue as I get a normal looking image for a split second.
      I have tested the...
      11-17-2020, 11:20 PM
    • robante15
      Acer Aspire 4520 won't turn on after reboot
      by robante15
      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
      If I remove the...
      04-06-2024, 06:50 PM
