Samsung un60f6300afxza led light 6 blinks
  • Keshenatech1
    • Apr 2018
    • 149
    Re: Samsung un60f6300afxza led light 6 blinks
    IDK if you looked at the date of my original posts, but this was a year and 2 months ago. I've fixed so many TV's since than that I don't remember this one. I average about 3 TV's a week part time along with working my full time job so this was about 150 of them ago.
      • 12276
      • U.S.
      Problem is probably in powerboard or backlights since the backlights did not come on, check numbers 2 and 3 below if you want to do testing and as always BE VERY CAREFUL working on PRIMARY/DEADLY side of powerboard.
      • brucetv
        • May 2015
        • 281
        • united states
        Here is a example of what Terryfictv is talking about. On this model I'll disconnect the cable from the power supply first and examine the connector closely for signs of arcing on both the cable and inside the power supply connector. Look at the top left pin on the power supply connector and see if you a sign of brown arcing and also on the cable end too. If it's nice and white I'll reconnect the cable to the power supply and leave the end off the main and then power it up. If the backlights stay on and steady then we found replacing the main board usually takes care of the power cycling issue. If the connector and cable looks brown then I replace both the cable and power supply and that usually fixes the on and off power cycling issue. Here's a couple of pics we found on the arcing issue on this model just like we see on the ES models.
          09-07-2024, 05:50 AM
        • Elecfronicsssss
          DA0NJJMBAG0 charging light blinks
          by Elecfronicsssss
          Laptop motherboard DA0NJJMBAG0
          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
          GUIDE ME WITH THE PROBLEM..
          SUMMARY-
          1.NO 1.8VOLTS ON BIOS PIN NO 8.
          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
          05-12-2025, 02:32 AM
        • Samunggg
          Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
          by Samunggg
          I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
          I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
          09-06-2023, 06:39 PM
        • Jackching
          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
          by Jackching
          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
          04-15-2024, 05:14 PM
        • Yanleb
          Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
          by Yanleb
          Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
          If they are not compatible why did Samsung give them the same part number to begin with?
          08-04-2025, 11:35 PM
