lg 47LC7DF
  • StoneRhino
    • Apr 2012
    • 9
    lg 47LC7DF
    So my neighbor comes to me toting this massive 48" TV. I help him into the house and we set the behemoth on the floor.
    He proceeds to tell me it wont turn on and that his son who "works on computers" looked at it and couldnt find the problem.
    Being someone who works on computers professionally, model railroads in O scale, and does electronics work for fun, I dig into the tv.
    First things checked was the cord, the wires going to the power board and then the fuses. The primary line fuse (8A) was solid, while the 5A going to the inversion circuit was reading open. Replaced the 5A fuse with a slow-blow glass so that I could witness the carnage. I put on my safety glasses and energize the circuitry.
    For about a second, I hear the brief hum of a transformer and then its quiet. I look at the secondary fuse and it had warped from blowing.
    The board is: EAY36781301
    The caps on this board look quite stellar, but the heat shield has discolored dramatically.
    Click for pictures (External Site)
  • StoneRhino
    • Apr 2012
    • 9
    Re: lg 47LC7DF
    I've done some more looking and the fuse goes to the longest heat sink bar. There are 4 small transistors and 2 larger ones, but the information for them seems obliterated and I cannot get a decent picture of them.
    I am hesitant to replace the caps if there's really no need to do it as the two very large 450v caps are 5$ each.
    Again, the fuse is instantly blowing the moment power is applied. Fuse #2 confirmed a potential short with quite a stellar pop and burst of light.
    • Hamie
      • Apr 2014
      • 1383
      Re: lg 47LC7DF
      Replace fuse with a 200w lightbulb.
      this way you can replace any suspect parts and won't risk damaging any new parts you install, also save you blowing any more fuses.
      • StoneRhino
        • Apr 2012
        • 9
        Re: lg 47LC7DF
        Interesting. I've never tried that before. What voltage do you suggest on the lamp? 110 or 208/210? Only thing I know of in excess of 200w is a halogen.
        Also I found a kit offered by Coppell TV Repair which includes the two large transistors I had mentioned and a few other bits for 15$.
        • StoneRhino
          • Apr 2012
          • 9
          Re: lg 47LC7DF
          On the positive upside, the repair kit I purchased stopped the fuse blowing issue. It took a long time to get here, but it wasnt all that bad to install.
          Unfortunately, I am sorry to report that the tv still does not power on. Still no standby power, so I am considering replacing caps.
          • Dannyx
            UC3842 Power Adapter Blowing Fuse
            by Dannyx
            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
            12-05-2023, 12:06 PM
          • Tips
            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
            by Tips
            Looking for some assistance please.
            Trying to repair a PD27AOQ samsung power board.
            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
            Testing it the fuse blows immediately power is turned on.
            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
            any assistance, guidance would be appreciated.
            04-11-2024, 11:24 AM
          • RogerH58
            Samsung 46" TV LE46B530 blowing fuse
            by RogerH58
            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
            06-10-2023, 10:27 AM
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • Bootleg1
            Samsung UN65KS9800FXZA T-con fuse blowing
            by Bootleg1
            Hi all, so i was watching tv acreen went black and no sound. Traced problem to blown tcon fuse. Replaced and it blows replaced again samething. So my tcon fuse keeps blowing. I bought a new board havent installed yet infear its just going to keep blowing the fuse. If i only connect the right side ribbon cable the fuse doesnt blow but as soon as i connect the left cable my tcon fuse instantly blows and no picture. The right side picture works clear as day and left side picture is grey (picture attatched) im hoping its a bad tcon board itself or a cable or anything and not the panel. Thank you for...
            02-04-2020, 01:05 AM
