Panasonic TC-P65VT50 7 blinks
  • Shinju
    • Mar 2014
    • 1239
    Re: Panasonic TC-P65VT50 7 blinks
    Well thats good news and bad news
    • djw43
      • Mar 2015
      • 95
      cracked
      so parts going to ebay, the good news is that i put the correct jumper on the p50GT30 i am working on, and I got power and fan spinning. I also got the SD card today in the mail, so I installed it and no SOS, but i do have this:
      is this patient dead too?
      here is the P50GT30 new thread, thanks
      https://www.badcaps.net/forum/showthread.php?t=45384
        That's a shame where was the crack?
        • djw43
          • Mar 2015
          • 95
          there is one starts upper left, goes all the way to the upper right and finds 10 more from the edge. My guess is that when it was on my truck the wind from over the cab pushed the top section and stressed it. Fortunately it was less than $200
          thanks again
          is there any chance for the other one GT30?
            Yes, the other one looks salavagable. You are brave to transport a plasma or LCD TV like that. I certainly wouldn't...
            • tw2005
              • Oct 2011
              • 6458
              I'm giving you 1 demerit point . If this is going to be the only way you have of transporting these I would get a large piece of thick foam or even an old mattress and lay it on it's back. Then drive lke you have the back of the car is full of eggs which you don't want to crack.
              I've transported all mine like that and not cracked one yet even having to drive for 2 hours at highway speeds. The glass is strongest vertical but as long as these are not flexed or suffer sudden shock they seem to survive.
              This is just my opinion, others may have better tips
              • djw43
                • Mar 2015
                • 95
                more like foolish, i should have laid it flat. That big of a screen is probably easier to crack
                Hopefully I can learn from my mistake, there seems to be plenty of good deals on these in my area. I have to be way more careful bringing them home.
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • OOF DIO
                  ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                  by OOF DIO
                  (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                  (Had 3 problems, now just 1)
                  I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                  I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                  I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                  04-19-2025, 05:03 PM
                • playit
                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                  by playit
                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                  09-02-2023, 02:43 AM
                • Leefreeman97
                  Diagnosing short to ground issue. pcb from an e scooter
                  by Leefreeman97
                  Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                  09-19-2025, 03:33 PM
                • ryogadan78
                  Xbox Series X
                  by ryogadan78
                  Good morning guys,
                  I am resuming an old service on an Xbox X Series that I really want to repair. I summarise what has been done because I can't find my previous post.
                  The Xbox initially did not turn on, no LED, no beep. Found short circuit on the 12V connector on the bottom board. Injecting 1.5V on the positive side of one of the shorted capacitors to find with the thermal camera which capacitor was shorted, no gave me useful information. The board draws 2.80A (1.5V), but from the thermal camera images I don't see any component getting hot.
                  I removed the coils one by...
                  11-16-2024, 04:46 AM
