Panasonic TC-P65VT50 7 blinks
  • djw43
    • Mar 2015
    • 95
    Hi
    I have a thread for a TC-P50GT25 but thought it is better to start a new thread.
    https://www.badcaps.net/forum/showthread.php?t=45071
    I just received this big boy and have removed the SC card, SC2 is shorted, I have checked the Q's (transistors) and have not found any shorts between legs. There is one area of the board that has some short tones however.
    see pics
    R588 one side shorted to ground (233)
    C551 one side short to ground
    C453 one side short to ground
    Q453 E short to ground 45F132 012 1229 (also q452, q451,)
    q421, q422, q423 DG301227C7u also have E short to ground
    diodes d462, d463, ( RFUH20 NS3S) and d421, d422 (DAF30A 141C5d) 2 legs each short to ground
    IC524 pin #2, #5, #6 short to ground part 4840 NA5 JRC
    Also, resistor R453 (5R6) is shorted end to end
    And D583, which looks like an LED, has open circuit both directions with diode test.
    I would like to try and repair this board, it is also available from shopjimmy
    there is another thread for a similar problem with a TC-P55VT50, fixed by replacing the SC
    https://www.badcaps.net/forum/showth...ght=tc-p55vt50
    Anyone feel like it could be repaired DIY? tw?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P65VT50 7 blinks
    It's repairable, but might be as cheap to get a board too. that way you can have fun trying to repair and have a working TV too.
    • djw43
      • Mar 2015
      • 95
      that's a great idea, I am going to order an SC on ebay, and then try to repair the faulty one.
      Do you think I am on the right track with those shorted components?
      Those are really the only shorts, other than the legs of the diodes that also give short tones. And SC2 is shorted.
      Would it make sense to lift those components off the board and see if SC2 is no longer shorted?
      thanks again tw
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        It is good practice to double check your findings out of the circuit. It is extremely rare for resistors to short. Usually the go higher in resistance, or open circuit. So the first 3 items on your list may be normal as one side actually is ground. So take all the offender you think out of circuit and measure again. Things could read a short in circuit, while not out of circuit. Have fun!
        • djw43
          • Mar 2015
          • 95
          Thanks very much for the input, I will pull those components off the board.
          I just double checked IC524 and pin 2,5 and 6 are shorted to each other and to floating ground on the board.
          Should those Q transistors have the "E" leg short to ground?
          Thanks again
          • Shinju
            • Mar 2014
            • 1239
            If this was mine I would send the old board to moduslink and have them repair it vs buying a shot in the dark used board that might fail.
            Mostly due to these boards being a pain to get the SMD parts off with out ruining the copper pads.
            Test your buffers too.
              You can see all those parts are connected to the copper ground plane. A short is normal. BTW, it is better to test across parts rather than from pin to ground - that way you can eliminate the need to find which pin is grounded (it doesn't matter)
              Have you tried isolating buffers and jumpering SC50?
              • djw43
                • Mar 2015
                • 95
                Thanks Shinju, I appreciate all suggestions!
                I actually sent a TNPA5081 (GT25) to modulus this week because that part seems to be so difficult to find. The cards for the bigger 2012 VT50 seems to be more available, $25 to $75 so I thought it would be an advantage to have a spare card, and also if it did work, to have a reference to try and repair the original SC from the TV myself. I did invest in a small rework station and preheater to do the best I can to avoid damaging the tracks or pads.
                Thanks again, I can use all the advise I can get, and I WELCOME it!
                Hi tom,
                Thank you for lending a hand!
                I do see now that you pointed it out, the solid ground plane that covers so much of the board. But for IC 524 it didn't seem normal for 3 pins to be connected to ground.
                I have quickly done some readings on some of the parts I listed above, but I still have many more to measure. all measured in circuit
                q421, q422, q423 all EG 99k GC 179k EC47k
                q451 EG 99k GC 290k EC 580k
                q452 99k 290k 112k
                q453 99k 290k 112k
                d462 600k/108k and .36/.36 diode test
                d463 28k/108k and .36/.36 diode test
                d421 46k/46k .26/.26
                d422 46k/46k .26/.26
                thanks very much guys
                • tw2005
                  • Oct 2011
                  • 6458
                  Hi tom,
                  q452 99k 290k 112k
                  q453 99k 290k 112k
                  nothing's leaping out at me short wise. across the sc2 pins what resistance? are you getting
                  • djw43
                    • Mar 2015
                    • 95
                    short .000 SC2
                    not seeing any shorts on any other qxxx between legs or to the C
                    gotta head out for work
                    thanks all!
                    • tw2005
                      • Oct 2011
                      • 6458
                      short .000 SC2
                      thanks all!
                      SC2 was measured isolated from the P board? If SC2 is short, ther's IGBTs shorted on the SC, there somewhere or have a go at the SC50 jumper, disconnect the buffers from the SC and remove the Vfg bolts(the ones that earth these to the SC)
                      • djw43
                        • Mar 2015
                        • 95
                        i have the SC board completely removed from the TV.
                        i just checked the resistance at SC2 again with SC50 jumped and not still dead short at SC2
                        gotta head out though , i will test the individual components again later
                        thanks tw
                        • tw2005
                          • Oct 2011
                          • 6458
                          thanks tw
                          sorry, should expanded. the sc is installaed and powered up with the buffers isolated and their gnd bolts removed, this wil prove id SC is working or not. if ok tv will turn on with no errors but if sc2 is shorted, no point.
                            thanks tw
                            Make sure to hold the probes for some time when testing w/ P board, as the caps can take some time to charge. Also check Vsus on P board (~215V) when powering up. If low, could be issue with SC/SS shorted or P board bad.
                            Not sure how these newer Pannys work, could a shorted Vsus trip SOS7 because Vscn/Vad did not rise when expected? (I would have thought it would trip out a different error first...)
                            • tw2005
                              • Oct 2011
                              • 6458
                              ST50 guide , should be of some help
                                Yea, so 7 blinks can be "Missing or shorted Vsus" according to that doc.
                                Seems to indicate that P board doesn't trigger it, rather that SC triggers it because the sub voltages don't come up (7 blinks usually Vscn/-Vad check)
                                Some older panels will do 6 blinks as ER mid has "priority" over 7 blinks, but I guess it depends entirely on the model as to exactly what each does...
                                • djw43
                                  • Mar 2015
                                  • 95
                                  cool, i hadn't seen that second doc, but that is the guide I followed, 7 blinks, disconnect P11, still had 7 blinks, disconnected SC20 went to 8 blinks, then found a short on one pin on each SU41 and SD42 and then did not have a short when disconnected those clips from SC. I then isolated SU/SD and the TV still clicked off indicating bad SC. And the SC2 shows a dead short.
                                  that's when I started checking the components on the SC out of the TV.
                                  • djw43
                                    • Mar 2015
                                    • 95
                                    MAJOR EDIT
                                    And I apologize for anybody's wasted time!
                                    I just double checked my SC50 jumper, and I was not getting continuity.
                                    So i stuck a different jack in there with SU/SD isolated and powered up, 3 relay clicks then power button, which caused some buzzing sounds from near the SC and also the SS board.
                                    The fans spin, and the LEDs are on both SC and SS.
                                    The diagnostics point to SU/SD, i did the probe test on them and did not find any shorts running the probe across the pins on each of the 10 panel connectors.
                                    But unless anyone has any other thoughts, I am going to order an SU and SD
                                    thanks and sorry for the misdirection
                                      Just to be sure, no cracks at all on the plasma panel? Even ones right on the edge?
                                      • djw43
                                        • Mar 2015
                                        • 95
                                        I will check closely as soon as I get home
                                        thank you tom
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • OOF DIO
                                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                          by OOF DIO
                                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                          (Had 3 problems, now just 1)
                                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                          04-19-2025, 05:03 PM
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
                                        • Leefreeman97
                                          Diagnosing short to ground issue. pcb from an e scooter
                                          by Leefreeman97
                                          Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
                                          09-19-2025, 03:33 PM
                                        • ryogadan78
                                          Xbox Series X
                                          by ryogadan78
                                          Good morning guys,
                                          I am resuming an old service on an Xbox X Series that I really want to repair. I summarise what has been done because I can't find my previous post.
                                          The Xbox initially did not turn on, no LED, no beep. Found short circuit on the 12V connector on the bottom board. Injecting 1.5V on the positive side of one of the shorted capacitors to find with the thermal camera which capacitor was shorted, no gave me useful information. The board draws 2.80A (1.5V), but from the thermal camera images I don't see any component getting hot.
                                          I removed the coils one by...
                                          11-16-2024, 04:46 AM
