lg 47LW450U
  • efwiofoi
    • Nov 2013
    • 76
    • uk
    lg 47LW450U
    i have an lg 47LW450U lcd, ive replaced the main board after the old one was apparently damaged by a spark between the hdmi port and a laptop hdmi cable.
    the new board is working but every 2 to 3 seconds the brightness of the screen changes, dimm bright dim bright continuosly. its only a slight change and either setting would be ok if it stayed on one. ive reset the picture and settings. its doing this on any input or with no input connected. its like either the backlight level is changing or the screen contrast or brightness setting is changing, i think it is the screen setting not backlight. i have a plug in power meter thats not showing any change in power drawn.
    any idea what would cause this? thanks
  • efwiofoi
    • Nov 2013
    • 76
    • uk
    Re: lg 47LW450U
    ive noticed that there are some lines on the screen when its in the darker mode, so its looking like a panel problem or something similar.
    the panel is a lc470euf(sd)(f2) and the new board came from lc470euf(sd)(p1)
    would that be enough to cause compatibility issues?
    • johnboy1313
      • Nov 2012
      • 1959
      Re: lg 47LW450U
      Are you sure you got all of the cables seated correctly when you changed the main board?
      • efwiofoi
        • Nov 2013
        • 76
        • uk
        Re: lg 47LW450U
        i think they are but will double check. the funny thing is the change is in time not random, its exaclty 3 seconds dim, 3 seconds brighter. something is controlling it it seems, but what could cause it to do that.
        • jean luc ferre
          display screen problems after changing motherboard
          by jean luc ferre
          First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
          I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
          Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
          Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
          09-11-2025, 10:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
