polaroid lcd tv trouble
  • BADHIGEEN
    • Nov 2007
    • 43
    Hello every one I'm new to this forum and I was hoping that you guys would look at these pics and tell me these cap are indeed bad. (fingers crossed) they are doamed out a bit. I traced the wires from the power plug to this board I am sure its the power supply/amp. The suspected caps read CapXon 1000uf/10v/kf105c. If these caps are bad what would be the best brand to replace them with?
    Thanx for any help
  • kc8adu
    • Nov 2003
    • 8829
    • U.S.A!
    Re: polaroid lcd tv trouble
    those are bad.
    i have been using panasonic fc.
    all the other crapxon on the psu output should be replaced too.
    those sets run very hot!
    • Krankshaft
      • Jan 2007
      • 2328
      I would recommend Panasonic FC series too. You can get them from Digikey.
      Those caps are so close to that heat sink I'm sure that attributes to their failure as well.
      For future reference whenever caps are bulging even a little bit they are bad and should be replaced. The bulging means that hydrogen gas has been building up inside the sealed can and it will eventally either leak out of the top vent causing a brown crusty solid to form on the vent or it could even explode.
      • BADHIGEEN
        • Nov 2007
        • 43
        Will pan fl series work?
        • Krankshaft
          • Jan 2007
          • 2328
          As long as they are low ESR and 105 C temperature rated since this is a switcher it is very important not to use general purpose caps.
          I was unable to find a datasheet for Panasonic FL series so I was unable to verify their ESR.
          • kc8adu
            • Nov 2003
            • 8829
            • U.S.A!
            fc are much easier to find and are well proven.
            i would definately use a non aqueous series.
            this novatek chassis runs way to hot for water based caps.
            • BADHIGEEN
              • Nov 2007
              • 43
              Hooray!!!! It works I took a chance cause I wasn't sure with the fl series they seem to be working fine pip works just like it did when it was new the whynning and wirzring sounds are gone and my channels change again Now on to the mobo threads.
              thanx guys
              • BADHIGEEN
                • Nov 2007
                • 43
                BUMP!!! So my big brother bought the same polaroid as me about a year after I bought my set. He has been using his for pc tv and what have you for about 2 years. About a month ago he noticed the same symptoms I had with my set till finaly the set wouldn't power up. Bro brought the set over today so I could have a look and sure as sh@! the same 2 caps had expanded easy fix I swapped them with the same ones I used on my set and his works again too here is a pic of the caps from his set and the polaroid working again.
                Both sets probly would have been trash to me with out badcaps.net forum Thanx again!!!!!
                • Krankshaft
                  • Jan 2007
                  • 2328
                  The Crapxon plague strikes again.
                  But to be honest the proximity of those mediocre caps next to that IC (a rectifier I'm guessing) is probably the cause for their failure. As you can see another Crapxon just as close to the heatsink is unaffected but the one next to the rectifier package (where most of the heat is generated before it's dissipated) have popped.
                  Bottom line bad board design.
                  Glad you're up and running again .
                  • kc8adu
                    • Nov 2003
                    • 8829
                    • U.S.A!
                    all those megmeet psu's run too hot.
                    • BADHIGEEN
                      • Nov 2007
                      • 43
                      So I went to see my daughter today and turns out her Grampa Mike bought her a polaroid from a pawn shop a few months ago just like mine and my brothers. Since then it has stopped working. I brought it home and took it apart guessing it would be the same and sure enough those 2 same caps were bulged out plus 1 more. Blast not as easy as the other 2 sets to fix but mine is a spare set I use for lan parties now. I swapped sets with her and will order a bag of 20 caps from ebay. Its a good thing I saved the box for easy transport.
                      Here are a few pics.
                      crapxon kf 105c 1000uf 35v
                      • JD Danger
                        • Aug 2009
                        How do you go about replacing these caps on the Polaroid LCD tv? Do they just snap in or do they need to be soldered? Is this an easy home repair or a professional job? Where do i get these caps?
                        • PlainBill
                          • Feb 2009
                          • 7034
                          (Imitating Arte Johnson), Verrry carefully.
                          Soldered.
                          I do it at home.
                          Digikey
                          PlainBill
                          • tmwalsh
                            • Jan 2009
                            • 119
                            JD Danger, I went to Radio shack way back when and bought a desoldering iron that has a sucker bulb on it. Let it warm up until it will melt the solder, pre-squeeze the bulb, place around the capacitor lead on the solder side of the board, make sure solder has liquified, and release the bulb. It will scoop up the liquid solder, which you then have to spit out onto an appropriate surface (hot, dang it). The leads will be loose or very close to loose and may need minor touch up with the sucker or another soldering iron to get that last tiny bit holding the component in place.
                            Some use a solder 'wick' which is basically a fabric made of copper. I have some, but don't know how exactly to use it. Place it on the lead, and then push on the iron or get the solder liquid with an iron and push the wick on the liquid solder... I dunno.
                            tom
                            • Chrissygizmo
                              Polaroid p49fn0038k backlights flashing split second
                              by Chrissygizmo
                              Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                              When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                              Any help would be greatly appreciated
                              Thanks in advance
                              11-10-2022, 10:30 AM
                            • crazycavan
                              polaroid TQLHD24PR004 no power
                              by crazycavan
                              hi, my tv no longer starts like dead, no standby led
                              motherboard : MS36639-ZC01-01
                              panel : V236BJ1-P01
                              flash spi: GD25Q64
                              need usb firmware or to reprogram​
                              05-05-2024, 08:40 AM
                            • f-bone
                              Having trouble with Fujitsu D2703-S BUP bios
                              by f-bone
                              Hi guys,
                              I am having trouble finding a way to create a 512kb bin file from a fujitsu motherboard .BUP file.. I renamed it to zip but there are a few files in the I do not know how to combine to a .bin file.
                              Please help.
                              BR,
                              george...
                              03-15-2024, 05:20 AM
                            • snimmits
                              Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                              by snimmits
                              Good afternoon,
                              I have a Polaroid P43D300.
                              It shipped with WiFi and Bluetooth.
                              Two weeks ago, I ran through the first time installation.
                              This did a full reset and went through the first time setup.
                              Once complete, I went to settings > sound.
                              selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                              search completes and doesn't find any devices.
                              I have tried everything I can think of.
                              Can someone provide...
                              03-01-2024, 09:26 AM
                            • Thefixinator
                              Having trouble getting Flexbv to work to view openboarddata files
                              by Thefixinator
                              Hey guys, I'm feeling like a noob trying to get flexbv to work to be able to download and view a particular board view of a mac mini 2018. Ive tried to read how to use the open board data but it's appearing to be a little confusing on how to actually look up a particular boardview. I'm using the free version to get my feet wet with the software. Ive checked to make sure under the program preferences the openboarddata.org is in the right spot which appeared to be there by default but im not able to open up and board preference to search for a specific board view. I'm probably confused on how it...
                              Yesterday, 11:51 PM
