Viore pdp42v18ha
  • ta630
    Steve
    • Mar 2015
    • 4
    • usa
    Viore pdp42v18ha
    Okay people I have been through tom66 troubleshooting for plasma tv
    Will post a picture if needed but I have no voltage on the vs side of the power supply
    My question is I have a picture that is viewable at night but very dim in the day
    I had to turn the brightness down to even view the picture
    Would a bad power supply cause this
    Viore pdp42v18ha
    I belive its a lg power supply
    Thanks for the help
    Steve
  • ta630
    Steve
    • Mar 2015
    • 4
    • usa
    Re: Viore pdp42v18ha
    First picture is the tv screen
    Second is the top of the power supply
    and the third is the bottom of the power supply
    • Shinju
      • Mar 2014
      • 1239
      1st you will need to verify your SMPS voltages to the sticker in found on the inside of the panel.
      I suspect this is a bad X/Z board as the picture looks very washed out and faded.
      • ta630
        Steve
        • Mar 2015
        • 4
        • usa
        vs voltage was a touch low at 185
        now set as per sticker at 186
        vd voltage spot on at 60
        5v is showing 4 volts
        The reason for not showing any voltage last night
        Replace batteries in multimeter
        Thanks Steve
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • Goldenmonkey
          Samsung pn59d530a3f no picture after power supply replacement
          by Goldenmonkey
          My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
          after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
          Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
          04-07-2023, 09:39 AM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
