LG 32CS460-UC bad panel or tcon board
  • NUTIN2LUZ
    • 61
    I picked up this TV and wanted to know if this is a bad panel or bad tcon board. Click on the link to watch the video.
    http://vidmg.photobucket.com/albums/...324_182934.mp4
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 32CS460-UC bad panel or tcon board
    Panel seen this a few times before.
    If you take it down to the panel. Your problem isn't the top ribbon connections it actually the ones on the side. They don't actually connect to anything but for some reason, probably heat related they can distort the picture.
    • NUTIN2LUZ
      • 61
      Thank you Hamie.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I had a Samsung LN32C450D 1G doing something similar. My upper screen was faded and the bottom about the same width showing good picture. Tried a new T-CON and that didn't work...So I went with bad panel diagnosis.
        However I am looking for a main board for a LG 47" if you are scrapping for parts.
        • NUTIN2LUZ
          • 61
          What's the part number? I can check my bins when I get home tonight.
            I concur, panel.
            The little things hanging out the edge of the panel aren't useless - they're the gate drivers. They get their drive signal through the LCD glass itself and chain the signal to each IC. If they go bad you will see something like this usually only affecting 1/4 of the screen.
            • NUTIN2LUZ
              • 61
              Thanks tom66. I guess this TV is scrapped for parts.
              • Hamie
                • Apr 2014
                • 1383
                Originally posted by tom66
                I concur, panel.
                Cheers Tom, always wondered what they were for. Googled it before but didn't really get an answer.
                Learn something new every day on here.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I'm seeing a trend with LG panels with this problem.
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
