Painassonic TC-P42S1 A Board Zener Diode
  • TVRepairNoobie
    • Feb 2015
    • 158
    Hello Everyone,
    I need help locating a source to buy this Ref. D5693 Part No. B0BC6R600005 Zener Diode, thanks.
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: Painassonic TC-P42S1 A Board Zener Diode
    Here is the picture.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      take the other diode out of the IC to the left and measure the "knee" of the zener. Should be the same diode.
      RLZ6.8B Brown Yellow Green
      Are these colors correct?
      btw... I think it is a Rohm LL-34 package Zener Diodes RLZ Series
      • TVRepairNoobie
        • Feb 2015
        • 158
        Hi CapLeaker, thanks for your reply.
        Yes, you are correct on the colors. D5693 is shorted on the pictured board, on another A board that I have (the measurements is 321 and with the probes flipped 698).
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          Diodes can measure weird in circuit, so test it out of circuit again. Zeners are hard to check with the DMM, unless it is shorted. If it is leaky, you need a Zener testing device, but if you have another board, just change the Zener out.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5095
            • New Zealand
            Yeah you need a proper zener tester to find the breakdown voltage, a DMM usually won't output enough voltage.
            -David VanHorn
            • TVRepairNoobie
              • Feb 2015
              • 158
              Guys, Thank you for your input it’s much appreciated.
              • TVRepairNoobie
                • Feb 2015
                • 158
                I just got my TV going again with an A board I had ordered off of eBay for $24.99. So, awesome it worked. (TV had 10 blink code)
                • tw2005
                  • Oct 2011
                  • 6458
                  Did you progress with the zener issue at all. I was just looking at the cct and i get the impression it's for protection so if it was just that zener shorted but the cct was not with it removed would it have worked without out it?
                  • TVRepairNoobie
                    • Feb 2015
                    • 158
                    Hi tw2005,
                    No, the extensive zener diode testing was beyond me.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                      I was working on this CNC machine today found no keyboard functioning no control relay powering on
                      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                      Found shorted diodes on main controller relays there are 3 of them that...
                      01-07-2023, 05:43 PM
