I've read quite a few topics on this forum, but since this problem is intermittent I haven't successfully diagnosed it.
The TV is a Samsung 43" Plasma - model PS43E450A1WXXU.
There are no bulging capacitors, most of the time the TV works and the time to picture loss is not constant, but could be heat related.
Previous searching on the internet led him to buy a replacement Logic board but he bought used so it could have the same problem. I fitted it for him and it has intermittently failed since, first occurrence was less than a day later.
I've since obtained this TV permanently from a relative who has replaced this and had it sat around because he didn't want to miss crucial moments of sports games due to picture loss.
He said that it happens completely randomly, regardless of input source (although only used TV tuner and HDMI) and said that most of the time it's after it has been running more than 30 minutes although on one occasion the picture went after 15 seconds of turning it on from cold in the morning.
I have checked some voltages but only while it was working fine but with no source connected. While I have had it I have only made it fail once with the back off but didn't have the TV in a position where I could measure (stood upright and poor lighting in the room it was in).
X-Buffer to Y-Main (I think, position Top Right) Connector CN4003
Pins in the order printed
11 DGND 0
10 OUTL 80V
9 OUTL 80V
8 OUTL 80V
7 DGND 0
6 DGND 0
5 VS 209V
4 VS 209V
3 DGND 0
2 15V 15.19V
1 DGND 0
PSU to X-BUFFER (I think, position Centre Right) Connector CN802
12 VS 209V
11 VS 209V
10 NC 0
9 VA 58V
8 GND 0
7 B15V 15V
6 B5V 5V
5 GND 0
4 VS_ON 3.24V
3 VS_ON 1.34V
2 PS_ON 169.3mV
1 GND 0
I'm open to suggestions for places to check, troubleshooting routines, ways to force it to fail to identify the problematic board/component.
I'm interested in repairing the faulty board if it is possible.
I have bought an 150MHz oscilloscope (Tektronix 2445A) without probes, so I still need to figure out what are the right probes to buy for working on these types of electronics. I figured out I most likely need just passive 10X probes, but I don't know if I need the full 150Mhz rating for this sort of work. Then I will hopefully be able to see failures easily once I know how to probe the high voltage stuff safely after a bit of practice (and maybe guidance from this forum).
After having said all of the above, the following link seems to suggest that the problem board is likely to be Y-Buffer, but my problem is intermittent not permanent so I'm not convinced.
Also having followed the advice on there I have checked the Logic board light flickers 1 time every second so should be deemed good?
When I made it fail the yesterday it was flashing maybe 1 time every 6-10 seconds (I wasn't counting with a time source to hand).
11 DGND 0
10 OUTL 80V
9 OUTL 80V
8 OUTL 80V
7 DGND 0
6 DGND 0
5 VS 209V
4 VS 209V
3 DGND 0
2 15V 15.19V
1 DGND 0
12 VS 209V
11 VS 209V
10 NC 0
9 VA 58V
8 GND 0
7 B15V 15V
6 B5V 5V
5 GND 0
4 VS_ON 3.24V
3 VS_ON 1.34V
2 PS_ON 169.3mV
1 GND 0
