OK i have this tv, wont power voltages in conectors cn2 and cn3 psu are ok, i already replace the output caps just in case,,, what i found kind of weird is voltages on big fat transistors in logic board go up and down every 2 seconds,,0.7v->3.7v U3 and 0.7->1.2v UD1,,,, any ideas,,anyone have the diagram ??
toshiba 32SL410U
Re: toshiba 32SL410U
Can you pleas give us the list of the Voltage reading of the connectors CN2, CN3.
Please make sure to list each pin names, pin number, follow by the Voltage readings when TV is OFF and when TV power switch is activated.
For example of what kind of format we are looking for:
CN2:
PIN 14:12.0VDC TV OFF = XX Vdc, TV ON = XXXVdc.Never stop learning
The reason I asked the Voltage readings is to find out at least if the STBY power supply is steady or not, if it is not, it will cause other the Voltages to go up and down as well.
So is the STBY power supply steady?Never stop learning
