TC-P50GT25 blinks 4 or 10
  • djw43
    • Mar 2015
    • 95
    Re: TC-P50GT25 blinks 4 or 10
    Thanks tw for that info I feel bad that you wrote all those part numbers, but that's great info.
    I really appreciate the help.
    this baby is off for repair.
    the p50gt30 I would like to repair myself.
    -dave
    • djw43
      • Mar 2015
      • 95
      Hello, TC-P50GT25
      By isolation, I have determined that the SS and SC both need work.
      The SC I sent to moduluslink,
      here are measured resistance's for the Q's on the SS board
      all are approx 47k E-G
      all are is least 400k E-C and G-C
      Q101 and Q102 RJK2017
      Q001, 002, 021, 022 30F125
      Q041 and Q051 45F128
      there are also 4, 5-pin small q's that I don't see any shorts on 3Y0E4
      Q055, Q056, Q141, Q161
      the vsus on this board sounds a short tone for continuity the white pin #1 SS11
      any ideas of where else to check for a short? I have a rework station incoming and would like to try and repair this card, even if I buy an extra SS for $25 ebay.
      next question:
      without SC, SU, SD, SS The p card is connected to the A card, the A card is connected to the 3 C cards.
      When both ribbons from the A (A31, A32) are connected to the C2 and C3, and the C's are coupled together I get SOS 6 blink
      if C1-C2 is uncoupled (c10-c20) or if C2-C3 is uncoupled (c26-c36)
      no SOS.
      if just A31(no A32) is connected to C2 no SOS even with all 3 coupled,
      if C3 is connected to A32 (no A31) and all 3 cards connected, then SOS 6 blinks, if either C1 or C2 is uncoupled (c10-c20 or c26-c36) then no SOS
      The SOS problem is when C3 is connected to A and all 3 C's are connected.
      what can I conclude?
      thank you
      edit:
      I have since ran a continuity probe across all 4 of the C couplers. c10,c20,c26,c36 and each one has some shorts as I zip along the ribbon connectors with all of them isolated from each other, and without A31 and A32. I don't know nearly enough to know whether this is indicative of all 3 C cards being faulty, or whether normal?
      • tw2005
        • Oct 2011
        • 6458
        Originally posted by djw43
        Hello, TC-P50GT25
        next question:
        no SOS.
        thank you
        edit:
        I don't want to sound rude but, why? You're doing a whole lot of unnecessary fiddling with little knowledge. As far as I'm concerned fault finding is completed and the offending board sent away for repair.
        Put everything back to how it should be and wait for the board to return. If a fault remains after this then we can investigate.
        • djw43
          • Mar 2015
          • 95
          ok
          • tw2005
            • Oct 2011
            • 6458
            ok
            Just want to see you have a win and get a working TV with the money invested. hate to see the panel damaged fiddling. Those bottom ribbons, whatever you do do not experiment there or run the TV with any of those unbolted. those ribbns have ics embedded if damaged or burnt, that's it, damaged panel.
            Did you get that dead 5081 board?
            • djw43
              • Mar 2015
              • 95
              no, i got outbid, but he is going to list another one. I think with the rework station and preheater, the fix is doable on That SC.
              this is the ribbon i disconnected which keep the TV on without SOS (no SC, SS)
              but i tested the GT25, the pic is of GT30
              • tw2005
                • Oct 2011
                • 6458
                Look, I'm sure there's a few steps to prove what's good or not. You found sc2 shorted and that's it as far as the 10/4 blink scenario goes. It's a common failure, they all pretty much go this way or occasionally maybe an A board.
                6 blink is SC related, we already know that board is bad so it's not something worth chasing.
                If you disconnect sc20,sc2, everything else hooked up = 6 blink = normal result, now disconnect c10, = 8 blink also normal result.
                I usually get people to disconnect sc2,sc20, p25, ss11 and 3 white ribbons on the A board and you should get same no error and TV on. if run for more than 30 secs it can then shutdown to 4 blink (normal) not recommended to run more than 30secs. Tis confirms you do not have a hidden 1 blink (a board and also confirms A and P are good. you've already achieved this result not worth trying again for the fun of it
                do not reconnect any power leads sc2,ss11 or p35 imediately after a power on or you can spike the boards and panel causing damage in particular p35 as that goes to those c boards and can blow those chips on film = dead panel
                I think hot air rework is overkill to repair the board but then I've never had one or used one. probably would give it a shot oif i did, too slack to spend the $$$ on one and I'm cheap
                • djw43
                  • Mar 2015
                  • 95
                  yay, I got my SC back from modulus, plugged it in and Action!
                  thanks guys, it's nice to get a win!
                  • Biruslapio
                    Panasonic P58V11B 8 and 12 blinks error "fix"
                    by Biruslapio
                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                    04-13-2021, 07:13 AM
                  • Andre Gilbert
                    by Andre Gilbert
                    11-20-2024, 08:52 PM
                  • Taurus12
                    Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                    by Taurus12
                    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                    Any recommendation on what I have to do next? Thanks in advance
                    06-10-2025, 05:05 PM
                  • GRANDGG
                    LG 42lw4500 flashing red light , wight light , 2 clicks
                    by GRANDGG
                    Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                    05-09-2025, 12:27 PM
                  • jchon
                    Sony A1e 5-blinks help
                    by jchon
                    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                    I found the service manual, which was critical to know where to probe.
                    https://www.manualslib.com/manual/20...1e-Series.html
                    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                    Unfortunately the 5-blinks...
                    06-28-2023, 11:52 AM
