TC-P50GT25 blinks 4 or 10
  • djw43
    • Mar 2015
    • 95
    Re: TC-P50GT25 blinks 4 or 10
    looks like my card is TNPA5081AP $85
    http://www.moduslinkptstvboards.com/txnsc1mmuu/
    the TNPA5081 no suffix is $68
    http://www.moduslinkptstvboards.com/txnsc1lvuu/
    Are any of these cards interchangeable?
    • djw43
      • Mar 2015
      • 95
      looking at the SS card, i have shorts on D001, 002, 051 on pin A to pin A.
      On SS11, its crazy, with extech digital mmeter i get mega ohms then switch probes i get short tone on pin SS11 white to ground, so SS is bad too?
      • djw43
        • Mar 2015
        • 95
        Originally posted by tw2005
        just use the pin numbers at the relevant connectors on the buffer boards and gnd at the mounting plates. Try switching the probes around but so far for the Su you've listed
        Vfo states 2.2Meg, you say 2.5 meg, i usually get about 1.9Meg on a fluke 73.
        This would normally show short on a bad board, I say pass
        VSCN-F (TPSC1) states 221K, you say 220K, I get 220K- pass
        5V_F states 5.7Meg, you report ? What is the range limit for your meters? I get as quoted with my meter
        confirm Su 5V_F,
        Now repeat process for the SD, looks promising
        gnd on these has nothing to do with chassis gnd
        on TPSU17 and TPSD26 i am getting erratic readings, from zero to OL. and i get a short chirp for short at first touch on each of these pins.
        • tw2005
          • Oct 2011
          • 6458
          sounds like your meter can not read it and the cct is charging. if it goes to OL and not a constant beep these are probably ok. you never did come with an answer for the limit of your meters
          • tw2005
            • Oct 2011
            • 6458
            that is normal,
            • tw2005
              • Oct 2011
              • 6458
              they do not have boards in stock, yours will be repaired so the cost is $85
              AF would work , no suffix is for 54', never understand how that one can be cheaper to fix as it has the most transistors on it
              • djw43
                • Mar 2015
                • 95
                hi
                looks like 40m ohms
                http://www.extech.com/instruments/re...ets/22-816.pdf
                • tw2005
                  • Oct 2011
                  • 6458
                  $85 looks pretty good right now!
                  As i went down your list they looked more and more difficult.
                  IC771 with AE on it 3 pins under and one above, doable
                  773 is smaller and looks like it has 5 solder pins
                  q701 is small but accessible
                  702 a little harder
                  818 even smaller, 3 pins
                  IC521 chip 1737FP, i would not know how to remove that one, copper braid? hot air?
                  I salute your skill!
                  well I am going to look into modus for my TNPA5081, thanks
                  I will be back...
                  The M81737 chip is not too hard, flood both sides and use 2 irons running them up and down so all pins molten and flick it off. or very carefully cut each leg hard against the casing even on one side then flood the other side with solder and move or cut legs both sides them desolder the remnants.
                  IC773 is awkward and I've lifted the tracks a couple of times
                  • djw43
                    • Mar 2015
                    • 95
                    Thanks . $85 doesn't seem to bad, when I look at hose teeny tiny chips!
                    I would consider trying if it was just for fun or practice, but not on this card, the TV is much more fun working.
                    • djw43
                      • Mar 2015
                      • 95
                      I do not mean to thread jack my own thread but I think I may be able to interpret the varying resistance measurements.
                      I just got a TC-P50GT30 (pics below) 7 blinks
                      SC2 pin 1 short steady tone P2 connector off
                      P11 pin 1 vsus short steady tone with all connectors off
                      P11 pin 4 P15v quick chirp and resistance starts at 0 and moves up 1k every few seconds no connectors.
                      The SS11 also quick chirp but the resistance starts 0L and then works its way down from 40m and slows when its below 10m
                      P35 pin 1 vda also short on P board no connectors, same pin on the cable to c25 is 67k and 73k probes reversed (C's ok )
                      Can I assume P board and SC are bad, SS and C's are OK?
                      I will test SU and SD later.
                      Is it safe to assume, if I get a chirp and the measurement starts 0L and decreases from 40m "no short" and if i get a chirp tone and the measured resistance starts at zero and increases by 1k for a few seconds then "short"?
                      GT30 pics, surprisingly different than GT25:
                      • djw43
                        • Mar 2015
                        • 95
                        I am testing my SU tnpa5090 for p50gt25 and SD tnpa5091
                        I have them removed from the case and I have measured resistance with both an analog and digital multimeter, with the leads flipped each. The digital mm has a 40m ohm limit.
                        Since they are isolated out of circuit there is no sc50 to jump.
                        I would like to know if these readings indicate that these boards are functioning, or is there another method.
                        Digital first:
                        SU41 pin 2 TPSU15 6.2m 0L when probes flipped
                        pin 4 TPSU 16 221k and 220k
                        pin 8 TPSU17 0L and 226k
                        SC42 pin 1 6.7m and 0L
                        pin 2 220k and 220k
                        pin 6 0L and 36k
                        analog:
                        SU41 pin 2 TPSU15 300k and 20k audible tone for short
                        pin 4 TPSU 16 200k and 30k
                        pin 8 TPSU17 9k and 20k audible tone for short
                        SC42 pin 1 250k and 20k audible tone for short
                        pin 2 200k and 30k audible tone for short
                        pin 6 10k and 20k audible tone for short
                        I would like to send my SC for repair, but I don't want to use these SC SD if faulty
                        thanks
                        • tw2005
                          • Oct 2011
                          • 6458
                          Digital first:
                          pin 2 220k and 220k
                          pin 6 0L and 36k
                          analog:
                          thanks
                          I'm confused, results now different to the first info you provided. use the digital and use diode check with continuity beep and place one probe on the gnd plate and slowly slide the other along the face of the pins for the panel ribbon connector for each and every one on both buffer boards and see if it shows short. constant beep or low ohms
                          I can't tell if good or bad the info seems wrong and erratic a bit from the meters
                          • tw2005
                            • Oct 2011
                            • 6458
                            worse case you send them to modus to check with the sc.
                            not sure how much they charge for that
                            • djw43
                              • Mar 2015
                              • 95
                              Thanks again tw for the attention.
                              I am also confused, that's why I thought it would be best to retest those pins.
                              I used diode mode with sound, plate grounded one probe, and ran slowly along each of the 10 screen ribbon connectors and did not get a short tone.
                              But I agree that since I am sending the SC, I should send the buffers also.
                              For my GT30 SC card, I have read that 3 or 4 others have had success just replacing the 6 mosfets:
                              https://www.badcaps.net/forum/showth...0gt30+7+blinks
                              I would like to go that route for the GT30 board, is there anyplace in particular for ordering screw kits?
                              thanks,
                              dave
                              • tw2005
                                • Oct 2011
                                • 6458
                                if you got no shorts at the output pins I'm going to say these are good because I have found when these go Vfo is always shorted and you will find shorted output pins.
                                that's the best i can do as a guide.
                                • djw43
                                  • Mar 2015
                                  • 95
                                  thank you again
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    thanks,
                                    dave
                                    I see screw kits on ebay and shopjimmy usually supplies them with the kits and also separate. the GT30 may need more than just those 6, it varies from what i've read and also the buffers can blow which are almost non existent.
                                    just scored a 50ST30, praying the buffers are ok or else I won't be able to fix it or it will e very expensive
                                    • djw43
                                      • Mar 2015
                                      • 95
                                      Fingers crossed, you'll see the components are nicely compact for thin case
                                      • djw43
                                        • Mar 2015
                                        • 95
                                        I checked my q components again on my SC board before i send it out, to be sure it's faulty
                                        results:
                                        Q661 short between EC
                                        oddly Q423 and Q401 also short EC but they have no component, just pads
                                        Q421, 422, 402, 403 and 452 short all legs
                                        And on the SS board TNPA5082AP i don't see any shorts on the Q's
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          results:
                                          Like I said earlier, highly unlikely SS is bad. The vacant locations on the Sc are for additional transistors in parallel with the other 2 for the 54" model, so yes you would see short on those if the rest of the bank have failed short.
                                          A typical repair of one of these I have found if all these are replaced they're fixed. 16 in total, least I've used is 7 and have gone over 30 after a failed repair. Not everything is bad all the time.
                                          I bet if you resistance check those 30F125 they don't show short but only have 200 ohms across some of the legs
                                          Q661 RJP63F3a
                                          Q701 MMBTA92
                                          Q702 2PD601
                                          Q818 2SK3018
                                          IC771 TA78L05F
                                          IC773 TC7SH14F
                                          Q421 DG402RP
                                          Q422 DG402RP
                                          Q021 30F125
                                          Q022 30F125
                                          Q402 DG502LW
                                          Q403 DG502LW
                                          Q452 45G128
                                          D482 RFM25TM4SW
                                          D451 RF071L4S
                                          IC521 M81737FP
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Taurus12
                                            Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                            by Taurus12
                                            Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                            I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                            i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                            Any recommendation on what I have to do next? Thanks in advance
                                            06-10-2025, 05:05 PM
                                          • GRANDGG
                                            LG 42lw4500 flashing red light , wight light , 2 clicks
                                            by GRANDGG
                                            Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                            05-09-2025, 12:27 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
