LG 50LN5750-UH horizontal lines
  • Iceman_GER
    • Jul 2014
    • 21
    Re: LG 50LN5750-UH horizontal lines
    what about those 4 wires going to the LCD ? Little plug top of the board.
      They are for the LED backlights.
      • Iceman_GER
        • Jul 2014
        • 21
        I may just order a mainboard and see if I get lucky.
          That would almost certainly be a waste of money.
          • Iceman_GER
            • Jul 2014
            • 21
            you also think it's the screen?
            • 50LN5750
              • Feb 2020
              • 9
              test
              • 50LN5750
                • Feb 2020
                • 9
                I have this same model that I have put new LED strips in. The tv worked fine and clearly for about 1 hour, then the image started shifting and had lines in it. Now it is permanent. I have taken photos to demonstrate the shifting from clear, to lines and back again. My next move may be to remove all capacitors on the power board, replace them with fresh ones and try again. Unfortunately I am not sure since it may be the panel. I'm posting for professional advice before I put more time and money into this set. I have a multimeter and soldering iron.
                • budwich
                  • Jul 2015
                  • 3097
                  it appears that you might have damaged the panel during the effort. :-( If the set has side tabs, you should check those to ensure that the disassembly / reassembly was done correctly and they haven't been "crunched" in the frame some how. IF no side tabs, then perhaps the "tape cutoff" method can be used to save the panel assuming the issue is only on one side.
                  • 50LN5750
                    • Feb 2020
                    • 9
                    Just removed the metal frames and re-examined the tabs, they are all along the bottom of the set.
                    • 50LN5750
                      • Feb 2020
                      • 9
                      Excellent success!
                      The tape method worked for this model! Refer to picture so you can see where I applied the scotch tape. What I really don't understand is WHY this fix works? Anyone have a technical explaination? Grateful for the help budwich!
                      • 50LN5750
                        • Feb 2020
                        • 9
                        Tada!
                        • budwich
                          • Jul 2015
                          • 3097
                          good effort.... it works because the method cuts off signals / voltages going to one side of the panel (that deal with the horizontal picture "elements"). On sets with no side tabs, the drivers are "built in to the glass panel".... by cutting off the "powering", those drivers remain turned off and don't impact the drivers on the opposite side. That's my take on things.
                          • 50LN5750
                            • Feb 2020
                            • 9
                            *Update* For anyone attempting this tape fix for their tv, I found the best results for zero lines in the picture is to skip the first two pins on the cable, then cover the following 5-7 pins. I honestly don't know how many pins I covered, it was trial and error, but it was not more than 11 total. I just know that I stopped immediately and sealed it back up when I had a good result.
                            • 50LN5750
                              • Feb 2020
                              • 9
                              Bad news on this repair, the line has re-appeared after about 50 hours of use. Anyone have any new suggestions? Now it seems un-watchable in this state.
                              • budwich
                                • Jul 2015
                                • 3097
                                think you might try "adjusting" the tape to see if you can change things.
                                • 50LN5750
                                  • Feb 2020
                                  • 9
                                  Are there any specific guides for this issue and model? For example, cover only the first 5 pins, 6 pins, 7 pins, skip over the first one or two pins etc? I get nervous each time I do this because I'm risking damage to the connector each time I handle it...
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    I have seen any but in general, it is likely that it is preventing powering going to the side drivers that in this case are built into the panel as opposed to tabs on other types of set. I would suggest not skipping any and keep adding width til the problem goes away. As long as the issue stays related to one side, I think this is your only bet. You might be able to "guess" based on the track traces that are coming towards the connector. With every connected (no tape), no power (not plugged in), get a meter and do a resistance measurement at the test points that you pictured earlier. Compare those measurements with those of the other side... hopefully they exist there in similar fashion. Go from there.
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • Ihandyrepair
                                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                      by Ihandyrepair
                                      Hi guys
                                      I just started fixing 4k TV few months ago. so I am still learning a lot
                                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                      then it started to show the ghosting white image.
                                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                      it has 3 thin small boards at the bottom of the...
                                      12-05-2022, 04:18 PM
                                    • ggil44
                                      Sony XBR-65X750D Horizontal lines bottom of screen
                                      by ggil44
                                      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                      05-30-2023, 07:51 PM
                                    • noisykid
                                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                      by noisykid
                                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                      12-30-2024, 07:15 PM
                                    • x_orange90_x
                                      Samsung UN46C8000XFXZA Horizontal lines
                                      by x_orange90_x
                                      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                      07-15-2023, 05:06 AM
