I have a 32 inch Dynex model DX-LCD32-09 with a TCON board CPT320WF01CVB that has C917 shorted. I removed the cap and the picture was restored. Anybody know what value the cap is?
Capacitor value needed
Re: Capacitor value needed
From the pictures of the board (through Google), it looks like an 0805 (2012 metric size) with at least few uF value (may be between 1~10uF). For a more reasonable guess, can you measure the adjacent capacitor which looks like similar to C917, if you have got a capacitance meter?
For voltage rating, measure the voltage present on the pads of removed C915. You will need a new capacitor which is at least 1.5 to 2 times the voltage at the pads.
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by veedoHello
I've got an Asus laptop which received with no power, so I found that one capacitor been damaged. I don't have schematics for that board which is DANJMMB11A0 REV:A
Without that caps laptop is turning on fine so problem more likely is sorted but I would like to put back the correct one as it should be.
If any way could help with sorting out specification somehow, I just know that my meter shows 11,2uF but is it 50V or 10V ?? or any others.
See attached photo off the capacitor, maybe someone have same motherboard and can check it for me please.
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Agent24I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
It has at least one problem.
The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
I have already ordered a replacement potentiometer, so that's not an issue.
Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
All are CapXon... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
- Loading...
