LG 50PC3D-UD Powers off 3 blinking lights
  • Scougar
    • Jan 2015
    • 6
    I've read a few threads on here about other members having issues with this set, and fixing them. I thought I'd give it a go. A neighbour was throwing this out so I salvaged it.
    Issue: Plug-in and it turns on for around 3 seconds. It turns off with 3 blinking lights, no display.
    So far:
    1) I have checked the fuses and they are all fine.
    2) I have unplugged the other boards from the main central motherboard, and the symptom does not change.
    3) I have soldered in new capacitors using a kit from ebay (before I realized that badcaps.net sells them!). Symptom remains the same. (Tried number 2 again, and also the same).
    Next Actions: I have read that the mosfets and temp sensors are potential failure points, but I don't want to cloud anyone's advice by saying that. How should I proceed with diagnosis? (I have downloaded the manual as in other threads, but it's not making a whole lot of sense to me at present).
    Tools I have: Multimeter, Batteries, test lights, wires, soldering iron etc.
    Thanks for any help in advance.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: LG 50PC3D-UD Powers off 3 blinking lights
    My guess is--It'll be one of the IPM's is short....
    Very common failure on old LG
    TELEFIX
      Agreed. Think it might be a good idea to check Vs and Va on the power board, with and without the Y- and Z-sustains connected (the two large boards either side of the display panel.)
      • Scougar
        • Jan 2015
        • 6
        Thanks gents. Are you able to point me to the test points at all, or a rough guide of what I'm looking to prove? (I'm very much a tinkerer, and am electrically inclined, but not electronically knowledgeable.)
        I had thought that it wasn't the IPM's as when disconnecting the power board from the rest, the set did not stay on any longer than previous (which is what I thought it was going to do if it was an IPM ?)
        • Scougar
          • Jan 2015
          • 6
          Ok, so I am going to focus on this again. Add mentioned I had bed replaced the capacitors with no change.
          I actually think the ipms are ok as I disconnect the boards and nothing changes. I need guidance where to go next with this.
          I would love to find someone local with this tv so I could see if the power board is the fault, and if it is check the screen to see if the tv is worth me buying or trying to repair the board.
          The intended use is in the garage for gaming.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            What are you disconnecting?
            IPM's are nearly ALWAYS the fault with these things....
            TELEFIX
            • Scougar
              • Jan 2015
              • 6
              Disconnecting what I believe to be the Y-sus and the Z-sus, which should allegedly make it power on for longer if they were the issue? (which it doesn't.).
              Interestingly... the lights (the row of 4 green led's) isn't always the same even with the same things plugged in.... very odd.
              I would be willing to spend $100 on a new board if I new that would fix it, but that's quite a risk.
              Hmm.. realized I hadn't uploaded a picture of the back of the unit.. will have to do that later.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Hows Vs, Va, when you try and fire it up, with and without Y-SUS connected and same with Z-SUS connected/disconnected?
                TELEFIX
                • Scougar
                  • Jan 2015
                  • 6
                  Not sure I was doing it right, but I appeared to be getting good voltages. I will look at the service manual and check where to test these again.
                  • bialag
                    Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                    by bialag
                    I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                    Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                    03-25-2025, 05:56 PM
                  • Audeze
                    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                    by Audeze
                    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                    Does...
                    10-06-2024, 08:54 PM
                  • Umadbro
                    Dell Inspiron 3481 (EDI72 LA-G714P) Powers with charger blinking code
                    by Umadbro
                    Hi, I've been given this laptop which upon plugging the charger it produces a blinking code, and it goes as follows:
                    "3 AMBER, 5 WHITE"
                    Pressing the Power Button, the machine seems to power up, as the fan spins (at a normal rate), but after a few seconds the power cuts off, and the cycle repeats.
                    Searching on Google for the blinking code for this device doesn't return any valuable information. The code is not listed on the service manual. However, I found out that for others or similar models "3 AMBER, 5 WHITE" blinking code...
                    01-18-2022, 06:38 AM
                  • dfear
                    MSI GP62 6QF - powers on, keyboard and power button lights up, then switches off.
                    by dfear
                    Motherboard is: MS-16J51 (i think).
                    Symptoms:
                    1) press power button: keyboard and power button leds light up.
                    a) nothing on the screen.
                    b) fans are not spinning.
                    c) no sounds.
                    2) after about 1 min 15 secs the laptop switches off.
                    Video of the issue: https://youtu.be/Q913lEgnYZ4
                    I have tried flashing the bios, which I download from:
                    here.
                    Not sure this board has a separate flash chip for the EC....
                    08-03-2022, 03:06 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
