LE32C450E1W Slight lines and white image
  • sordids999
    • May 2013
    • 2156
    hi guys
    got this tv today the picture starts fine then a few minutes later it develops slight lines on the screen then after 5 minutes the picture goes to a slight white pictures and stays like this,voltages seem fine im thinking another panel failure but would there be a slight chance of tcon ? but how could i test this im thinking its built into the panel ?
    i have uploaded a picture but it does not really show much unless you look to the top right with slight lines
    thanks
    Re: LE32C450E1W Slight lines and white image
    It looks like a panel fault. Perhaps try applying pressure to tab bond drivers.
    • sordids999
      • May 2013
      • 2156
      yeah tried that still the same tom oh well another one to strip
        Before stripping it maybe worth getting a can of freeze spray and cooling various parts on the bonded T-con board. Maybe something leaky/easy to find. No guarantees... but worth a shot.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • thstuff
          SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
          by thstuff
          This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
          Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
          1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
          2) Waited 30 seconds, then pressed remote Power button and "Select language"...
          01-30-2023, 05:01 PM
        • pharmadrahmed
          Sanyo TV FW55C46F with white vetical lines same place and image exists
          by pharmadrahmed
          I've those vertical lines in fixed spots ( don't move or flicker or change)
          tcon board by Lg looks working, voltages are normal. cleaned all flat cables and sockets.
          even withe t con board disconnected I still get those lines on the white backlight background. is it a defect of the panel itself? can it be fixed?...
          04-30-2022, 04:48 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • EazyBone
          75r648 TCL 8K Mini LED White Horizontal Lines
          by EazyBone
          TV turns on, lights work sound works.
          TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
          First experience with 8k and mini LED. Does this picture tell you anything?
          Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
          Any tip or trick on where to start would be appreciated.
          Going to research the lines. Also going to disconnect...
          11-14-2023, 06:42 PM
