Samsung LCD 52'' FXZA Horizontal White Lines in 1 section only, Scrap or Fix?
  • rrdr
    • Mar 2015
    • 7
    • ca
    I did some research and paid a guy on justanswers for a firm diagnosis. I would like a second opinion before spending $100 on a new main board.
    These white lines change to dots between levels when playing COD/ps3/hdmi. Is there any chance this issue is with the panel or do you agree with the tech this is probably a main board problem.
    thank you.
    ln52b750u1fxza
    LN52B750U1F
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung LCD 52'' FXZA Horizontal White Lines in 1 section only, Scrap or Fix?
    What did the test patterns in the service menu tell you?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Could be T-Con or Main....
      TELEFIX
      • rrdr
        • Mar 2015
        • 7
        • ca
        Thank you for the reply, Ill try and download a service manual online and go about testing.
        • rrdr
          • Mar 2015
          • 7
          • ca
          Thanks for the reply. Based on the picture, do you agree that its probably NOT the panel and secondly, should I start by replacing the board or Tcon? Does one fail more than the other.
          • Shinju
            • Mar 2014
            • 1239
            In my humble experience, lines goingnleft right usually equals bad panel lines going up-and-down usually equal bad panel also lines going up-and-down could mean bad main board or T-con, it really depends what the service menu testpatterns tell you they should pin point what exactly is going on for the most part.
            Samsung service menu entry, you will need an original remote, with the unit off and remote in hand press in this order MUTE, 1, 8, 2 and power.
            This should bring up the service menu, you will need to figure out were the test patterns are as they change from firmware to firmware also DO NOT MAKE ANY CHANGES on any options with out writing down the original config first, all changes made at the service menu level are permanent and can only be changed by entertaining my the Service Menu again and remembering what the original setting was you changed. Be very cautious when in the SM.
            • rrdr
              • Mar 2015
              • 7
              • ca
              Thanks again for the info. When you say lines going left right, do you mean the lines are shifting from right to left, ie moving across the screen. Or just the appearance of fixed horizontal lines?
              Ill order the remote and let you know, hopefully this might help someone else in the future.
              I also uploaded another picture, as you can see the lines are only in a certain spot.
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • ggil44
                Sony XBR-65X750D Horizontal lines bottom of screen
                by ggil44
                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                05-30-2023, 07:51 PM
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • noipi
                samsung Oled 65 Horizontal Lines and Flicker
                by noipi
                I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                10-14-2025, 02:11 AM
              • x_orange90_x
                Samsung UN46C8000XFXZA Horizontal lines
                by x_orange90_x
                I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                07-15-2023, 05:06 AM
