TC-P50C2 Shattered Screen, want to be sure boards are OK to sell.
  • johnboy1313
    • Nov 2012
    • 1959
    I found this TV in the trash. With all ribbons from the SU, the SD, and the SS disconnected, as well as C11 and C21, the TV powers on with no blinks and powers off as well. Are there any other tests I should perform before I part it out and scrap the chassis?
  • tw2005
    • Oct 2011
    • 6458
    Re: TC-P50C2 Shattered Screen, want to be sure boards are OK to sell.
    yep.
    I would resistance check the buffers and check for short between the Vfg plates and the buffer outputs, check sc2 for short and I'd also probe all igbts and diodes on the sc and also the ss in these tends to blow so likewise check ss11 for short and do the same and bell out all smd igbt, fets and diodes.
    sounds like the p, a and sc are ok with what you've done.
    the A,SS and Sc boards should yield some good $$
    • johnboy1313
      • Nov 2012
      • 1959
      Awesome. Thanks. I've got a P50S2 here with ten blinks that uses the same A board. From what I've read, it could be several things causing the ten blink code. Maybe I got lucky, maybe not.
      • tw2005
        • Oct 2011
        • 6458
        I think you'll find S2 is FHD so no good , c2 HD, connectors won't line up needless to say Hd won't drive FHD panel
        • tw2005
          • Oct 2011
          • 6458
          bad Sc could be the cause of 10 blink also, 5105 which is similar to the 5081 boards just cut down and fewer components
          • tw2005
            • Oct 2011
            • 6458
            you could easily prove if 10 blink is A by disconnecting sc2,ss11, 3 white ribbons at the A and I always disconnect p35. don't reconnect until all voltage is gone after power cycle
            • johnboy1313
              • Nov 2012
              • 1959
              It looks like both sets came with 5105 in some cases but, unfortunately, not this case. SC20 shows shorted. Lots of shorted components on this one so far.
              • tw2005
                • Oct 2011
                • 6458
                ok, so we talking the S2 now with shorts? Pretty sure S2 is 5105 SC and C2 is 5063 SC so what do you mean both sets came with 5105 in some cases?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Sorry, I just saw your reply. Shopjimmy shows 5105 as an option for both TVs depending on what panel was in it. At any rate, I got a solid red LED with everything disconnected as you directed, tw2005. I sold the board and now the buyer wants a refund because he says it doesn't work.
                  • tw2005
                    • Oct 2011
                    • 6458
                    There's errors on SJ and this is one. So refresh me, since we've been discussing a C2 and a S2. Which test? I gave you one with everything except the P and A board disconnected to help verify if 10 blink was A board or not for the S2. I don't think i gave you a procedure for the C2 since the panel was cracked as I was concerned shorted panel would blow boards.
                    Did suggest probing. So did you mark your board? What error did they start with, what do they have now?
                    • tw2005
                      • Oct 2011
                      • 6458
                      I still feel this proves most boards would be good, SS is the one that would have a question since the SOS8 is removed with c21 disconnected. The SS is prone to failure in these but if it failed like most, Vsus gets shorted so would expect an error blink on that or would be pretty easy to check that board with a meter.
                      Which board did you sell?
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        I sold the A board. I haven't got a reply back yet regarding the buyer's issue and what may or may not have changed. I've got his phone number. I plan on giving him a call later this morning. He just said it was "dead".
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          After rereading my post above, I wanna make it clear that I'm not blaming you in any way. I hope I didn't come off like that. I'm just looking for advice. Thanks for your help.
                          • tw2005
                            • Oct 2011
                            • 6458
                            No prob, a little surprised, sounds like misdiagnosis at the other end or trying it on. Obviously your A board was not completely dead otherwise you would not have got any result at all yourself.
                            definitely needs clarification.
                            I don't sell parts often myself, always fearful they'll misdiagnose, stuff it or be dishonest. touch wood the few i have worked out. Sold a complete set from LG cracked screen, turned out ok but was to a repair shop.
                            Hope this works out.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Have you verified they too have a 50C2?
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                No, their shop doesn't open till 10:00, 11:00 my time. It's only 8:00 now. I'll try and sort it out.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  In your opinion, if I get the board back, can I put it in the 50S2 with sc2, ss11, the white ribbons, and p35 all disconnected and the LED lights, doesn't blink, and will allow the set to power on and off as normal, does this tell me that the board is still ok?
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    would have to check the pinouts of the power connectors but more than likely. I know with my X20, same gen and scenario, the A boards in those for the baseline HD/FHD are all TNPH0840 but not interchangeable. I made the mistake of not checking and purchased a FHD A board in error for the HD model but was able to power it as you suggest with no ribbons(they won't fit anyway), no sn/ss etc and it turned on no blinks, no display.
                                    It proves the A board is not dead or producing any error blinks. Won't prove the picture is correct though but you'd be unlucky if that ended up being the case.
                                    The only other thing is the power switch whether it's integrated on the A board or on the front. Agian I'd have to check out the diagrams for C2 and S2 variants
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      S2 has a small soft touch button for power on the corner where the side inputs are, vacant on the c2
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        If I remember correctly, they were identical boards. Both had the AV suffix. I've been wrong before though.
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • ipatch
                                          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                                          by ipatch
                                          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                                          08-24-2024, 02:36 PM
