olevia lt37hvs re:pink screen
  • pookie21
    • Oct 2012
    • 11
    • australia
    Hi all out there, got this TV from friend because he did not want to bother fixing it. I have not opened up case as yet.Have no remote so manually turned set on then set to VGA .Can scroll through menu and source ok. I plugged in my laptop and played movie.The attached image is what i am getting.Have tried about everything to try to adjust out the pink but to no avail.Before i attempt anything i thought someone out there would have seen pink screen before .Would greatly appreciate any response.
  • Seeking Buddha
    • Jul 2015
    Re: olevia lt37hvs re:pink screen
    I had the same thing happen to me, then that even stopped. The set come on blue screen when I start it up then pops to black. When I use the manual controls on the bottom, the menu lights up fine. It happened when I was changing sources, I accidentally turned the TV on and off and I think I gave it some kind of surge, because that's when it happened. Please let me know if you ever found out anything about this.
    Thank you.
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • Yehuda170
      ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
      by Yehuda170
      original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
      replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
      now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
      with original broken screen i can see in device manager touch screen in human interfaces
      but with the new screen it's not showing in device manager
      is it lenovo blocking it? is it driver missing?
      I²C is a headache
      07-14-2023, 01:29 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
