can I test a main board out of a TV?
  • skyver
    • Feb 2015
    • 31
    Eg can I power it with a power adapter on my bench and test the voltage regulators and even use the serial port to access it
    Re: can I test a main board out of a TV?
    I have done this before with a board. It used 5V and 12V, but the CPU would work fine if only 5V was present. Using my scope I could see the "NO SIGNAL" data on the LVDS outputs which would change when I pressed buttons on the remote (the pattern of bits would change indicating a different image was being displayed.)
    • skyver
      • Feb 2015
      • 31
      Awesome thanks for the info mate
        • 31087
        you can get video from any scart conectors too sometimes, as it's for feeding vcr's and cable decoders.
          Depends on the model. A lot of TVs simply route the SCART outputs between ports - but this is just a set of analog switches so doesn't really tell you much about whether the scaler/video decoder are working. There is one exception I am aware of and that is some LG TVs have a "DTV Out" which is a direct capture of the Freeview and analogue TV stream.
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
