Re: New tool, Aoyue 8800! Desoldering just got easy!
i had a weller ds80, the cleaning is always a problem on vac tools.
to get the flux and other crap out of the end, use a drill-bit that is smaller than the hole when it's cold.
and if you use it a lot, empty the collector and inspect the filter atleast once a day.
The Hakko 808 I bought was only $170 or $180. The only issue I've had is not an issue with the gun itself: The tips can become clogged and rendered unusable if you suck up flux. The flux becomes hard like concrete and is difficult to remove. I haven't found a removal method that doesn't also damage the tip. Also, I haven't encountered a need to have a station separate from the gun. What were your thoughts in that regard?Last edited by capkid; 03-15-2015, 02:47 PM.
I hate to even have to revisit this thread and say this, but this thing is less than a month old and already has issues. The pump motor bogs down sometimes and then the suction is crap. I don't know if it's the motor itself, or just a bad connection. I haven't used it more than 10 times. I guess I'll tear it apart and see what it is. If you want one of these, I'd suggest saving up a bit more and getting a Hakko. Also, I think one where the pump is in a station rather than the gun would be better. Aoyue just lost me as a customer.
Originally posted by lookimback View PostThey could use a better label. It's not like this was cheap. $180, I think a foil label wouldn't cost more than a quarter.
WOW! I'm sold.
Originally posted by Agent24 View PostMaybe you should be glad, they might have used the money saved on the sticker to give it better quality wiring.
Wonder how long before Kada etc rip off the Aoyue!
Desoldering guns are pretty awesome compared to the one-shot pumps. But even those and braid are still good sometimes, desoldering gun doesn't work for everything.
I have a Den-On gun type one but I think I would prefer a station. I don't like the vibration from the pump motor. It seems to make it easier to damage pads sometimes.
Originally posted by Agent24 View PostSo Aoyue finally ripped off the Hakko 808?
Originally posted by capkid View PostYou can also add solder then suck up the solder on either side of the pin. You'll need lots of heat, so a heat gun is a must.
Originally posted by lookimback View PostI bought mine from sra-solder, but through their eBay store because it was $10 cheaper there. I wish they made a tip that could fit over the pins on large heatsinks. I guess that's my only complaint, but from what I can tell, none of the other brands make such a tip either. Maybe I'll buy a spare 1.8mm tip and bore it out.Last edited by capkid; 02-26-2015, 04:47 PM.
http://youtu.be/mEgRHT1EqVA
http://youtu.be/aC0d-WhHdZMLast edited by capkid; 02-26-2015, 11:59 AM.
Originally posted by Nerfinator View PostHow does it work? I use braid and pumps for my de-solder work but always looking for something to make it go faster. Time == $$$$
Originally posted by mmartell View PostRemoved another IPM from an LG sustain board last night with the trusty paint remover. Jesus would one of these come in handy. Just about turned the board into charcoal in the process, will have to look into the proper tool for the job.
Originally posted by lookimback View PostThis is going to make troubleshooting sustain boards so much faster. It comes with a nice storage case, but I think it will never see the inside of it again. I looked at the Hakko FR-300. This was about $80 less, and already $80 more than I intended to spend. My finger was literally hovering above the buy it now button for one of those S-993a guns, then I decided to look for some reviews on the 110v version. Glad I did.
