New tool, Aoyue 8800! Desoldering just got easy!
    replied
    Re: New tool, Aoyue 8800! Desoldering just got easy!
    those are from Ningbo Zhongdi Industry & Trade Co., Ltd.
    http://www.china-zhongdi.com/index.asp
  • dj_ricoh
    replied
    i got this.
    it was the cheapest one because i use to much wick on power supply to learn how to fix them
    the only prob is the internal vent its making a noise after 2 weeks but i know why. moisture in basement.
    the max temp i use it its 380c. it does the job flawless
  • Agent24
    replied
    Originally posted by lookimback
    And prior to last night, I'd only used it for a few minutes on a couple occasions. I had the temp on 480°C, I wonder if It's over powering the element?
    Maybe the temperature control is shorted and driving it full tilt all the time.
    All the reviews on Amazon give it 5 stars. Admittedly, there are only 4 of them, though.
    replied
    it *should* be, but that's not what i meant!
  • lookimback
    replied
    I think it's 120v
    replied
    i wonder if it's not a 24/36v element!!
  • lookimback
    replied
  • Agent24
    replied
    Wow, that is astoundingly bad quality, even for a Chinese junker.
  • lookimback
    replied
    I have a paperweight again. I used this last night for about 2 hours straight. I had 5 power supplies to rebuild, each with 9 components to remove. Towards the end, the pump started seizing up, it had no suction, and one of the screws which hold the tip assembly in melted out. Now, I just turned it on and the element is burned out again. These things are very poorly designed and are definitely not intended to be used. I won't waste my money fixing it again.
  • saddle_au
    replied
    I had both the Hakko desoldering station and hand held units and after 10 years of solid use, my Hakko handheld self-destructed. It had three screws through springs holding the barrel on and two of them gave way suddenly and it went 'bang' in my hand. The desk unit (soldering and sucking station) died about half a year later, again releasing piles of electronic smoke.
    In all, quality lasts but there comes a point where replacement makes sense no-matter who makes it.
  • lookimback
    replied
    Fixed. It was around $21.50 with shipping. It works good, but has a real flimsy feel to it. I know it won't last a year of regular use. I considered selling it on eBay Agent24, but I wouldn't risk tarnishing my reputation. I'll use it until it breaks again, I have to get some use out of it to minimize my losses, but once it breaks again I'll toss it and get a Hakko.
  • Agent24
    replied
    Hakko 808 is a better idea
  • alex987
    replied
    About the Hakko FR-300 here there are a lot of people having heating element issue.
    http://www.amazon.com/Hakko-FR300-05...ct_top?ie=UTF8
    Ah, about the pump motor, try to read this review:
    http://www.amazon.com/review/RB7LNF2...28013&store=hi
    It seems it isn't a good design...
    So, better to spend less (for an 8800) hoping it longer last, or spend more than double for an FR300, which seems to have some issues?
  • Agent24
    replied
    But is it worth it for something that was already broken twice in rapid succession?
    Maybe - if you used it to 'repair' the 8800, flog it off on eBay ASAP, then use the funds towards a Hakko...
  • alex987
    replied
    @ lookimback:
    You can buy the heating element here:
    http://www.sra-solder.com/c088-heati...esoldering-gun
    It costs $15
    I suppose this is the 110V version; 220V version should be different part number.
  • tibimakai
    replied
    Guys, get the real stuff, these copies or look a likes, are not the same!
    I have purchased these in the beginning and I have realized, that I'm just struggling with these tools and then, I had to buy the real stuff and at the end, I ended spending more. It's a joy working with the real stuff.
    I have got the Hakko tool, which is not much more expensive, if you buy it at the right time(when the price is lower) and it works as expected, or even better then expected.
  • alex987
    replied
    Thanks mate for the suggestion.
  • lookimback
    replied
    I got your message Alex, but couldn't respond to it. To answer your questions though, no, none of the parts from the 808 are compatible. They just made it look the same to lure people in. While it worked, it worked great. That was about 6 days. Even then though, I was noticing that it was poorly made. It's just not designed to last. If you want my advice, and others here will say the same, buy the Hakko. It's about $100 more but we'll worth it, and you'll never have to worry about the availability of replacement parts.
  • lookimback
    replied
    Originally posted by alex987
    Did you repair your unit?
    Not yet. Still waiting on availability of the part. Should be soon.
  • alex987
    replied
    I contacted them to ask if they have the element. I didn't even bother trying to return it. I'm just really put off by this and think I'm probably better off fixing this than taking my chances with a third unit. I doubt I could get a refund now because it's been over 60 days since the original purchase.
  • rex98
    HP DMI Tool
    by rex98
    HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
    DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
    The DMI Tool given here are for personal use only.
    DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
    You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
    from it, and that you please credit the author...
    07-02-2025, 05:51 AM
  • salim5566
    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
    by salim5566
    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
    06-26-2025, 03:25 PM
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool
    by shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool.
    Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
    anyone having it, please share
    Thank you
    07-08-2025, 06:42 AM
  • tony359
    Best tool to place electrolytic SMD caps on a board
    by tony359
    HI all,
    I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
    When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
    The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
    01-28-2024, 06:23 AM
