Panasonic TC-P42X3 will not start
  • Fwrothy
    • Feb 2014
    • 178
    Re: Panasonic TC-P42X3 will not start
    Tried sn3 again got 106K so idk...
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by Fwrothy
      Ya I read all the other thread for this model,that how I found the manual so quick. The only boards I've tried to repair sof far are PSUs, with varying success so this could be fun( if it was the A board then I'd pass).
      Anyway no loose screws on the SN, I no I read about this problem, gotta remove the A to get at SS. Wil post pics at that point.
      yeah well, whatever you want just keep in mind you have a sn hanging off it and if it goes south and takes that out too, the fun may turn to frustration.
      I'm an advocate for board repair but also had a couple of projects blow out making mistakes.
      • tw2005
        • Oct 2011
        • 6458
        go with just Ss replacement
        • Fwrothy
          • Feb 2014
          • 178
          Thank you for your help TW2005, I see the sense in what you are saying, I will get a board ordered asap.
          • tw2005
            • Oct 2011
            • 6458
            did you fix this TV?
            • Rensiee
              Panasonic TH-50PX8EA Black screen, only relay clicks
              by Rensiee
              I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
              I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
              When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
              I have measured the voltage in the VSUS line, which...
              06-18-2024, 12:58 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • valvashon
              Repair Success! Middle Atlantic UPS2200R-IP
              by valvashon
              Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
              Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
              02-06-2024, 12:54 PM
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
