dim display backlight?
  • jssurfer
    • Feb 2015
    • usa
    I own a LG47LH40 TV and it suddenly changes picture from a nice vivid pix to a much darker display, then stays that way. It was an intermitted problem but this time it seems to be staying permenantly dim. I am wondering If anyone else has had a problem like this. I thank you all in advance for any help you can give me.. Its a shame to toss the TV... Id like to try and do the repair myself .... worst I can do is break a broken TV right? thanx to all JS
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: dim display backlight?
    Is this an LED or florescent backlit display?
    If it's the latter, you can start by checking the inverter transformer(s) for an open circuit high voltage winding.
    Also, check for cracked solder joints. Inspect the wiring for the backlight for arcing or bad connections.
    Some pictures would help us too
    -Ben
    Muh-soggy-knee
    • jssurfer
      • Feb 2015
      • usa
      the tv is an LED I am curious if the dimming of the screen sounds like an issue w/ the backlight or could it be something else... I took just the back of the tv off and looked closley w/ a magnifing glass I see no swollen caps or burn marks anywhere... I dont have any paperwork to dissasemble it further and am wondering if there are any instructions to be found anywhere.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        It could be failing LED(s). It also could just be a dodgy connection. Or perhaps the LED driver is faulty.
        I'm not great in the service manual area of things, however there are a few folks on here who are, they likely will chime in sometime soon.
        In the mean time if you want you can upload some pictures of the circuit boards and post them on the forum here.
        P.S. I just noticed, you live in the garden state as well
        -Ben
        Muh-soggy-knee
          Can you change the setting from VIVID to user pref mod to see if you can adjust the backlights (not brightness) level? Also does it have the auto brightness that will change with the room lights? you may try turning that function off.
          • jssurfer
            • Feb 2015
            • usa
            reguardless of what I adjust, it stays dim,,, even called LG, the tec. talked me back into the factory settings... still dim,,, w/ auto brightness off picture is still very dark / dim.... its not an adjustmet... I think something's going bad to make it darken like this
            • signal.quest
              Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
              by signal.quest
              I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
              03-17-2024, 10:14 AM
            • lanovey
              SF314-41 BIOS without internal display
              by lanovey
              Hello there,
              I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
              I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
              06-13-2025, 02:38 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • dbuergi
              Acer XF240Y display backlight on and off then stays on but no display
              by dbuergi
              my display shows some strange bevahior. The backlight turns on, off and then stays on but i get no display or Acers logo. After some time it goes into standby. My notebook identifys the screen when i connect it by HDMI but i don't get an image.
              Voltages seem n​ormal and the only possible problem i found is the cap on C33 on the tcom board. It shows 0 Ohm and 0V in diode testing. Any ideas for next steps or what i can check?...
              11-14-2024, 04:36 AM
            • howardc64
              Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
              by howardc64
              Eventually discovered a burn mark near lower corner of LCD. Here is a summary
              • Backlight on, no image
              • Disconnect right buffer board (view from front), left side display comes on
              • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
              • Buffer board is pretty simple
              Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
              07-11-2025, 04:04 PM
