I have a Visio VF551XUT 55'' flat screen tv. The TV no longer turns on. The “visio” power indicator is amber when off. When the TV is turned on, the indicator changes to white and several “feature” lights sequence on as well. However, there is no picture or sound.
I have read several posts and attempted to troubleshoot the issue. This is where I am:
The issue appears to be related to the “ps on” output from the control bd.
When the power is turned on, I measure approx. 0.18v on the “ps on” signal.
If I isolate the “ps on” signal by disconnecting the black wire that goes to J1-1 on the control bd and pull that signal up on the pwr supply bd by using an external resistor (~1.6K) tied to 5v, the TV powers up and I get normal picture and sound.
If I leave the black wire connected between the control bd and power supply and try to pull up using the external resistor, the signal goes to approx. 1.45v – not high enough to turn on the main supplies.
I'm trying to track down what the issue is on the control bd. It is a bit difficult to trace the signals without having a schematic given that the control bd is multi-layer.
I tried to trace back from J1-1 but am having difficulty. I can trace thru R11, R1, R23, C328 to Q7; some interconnect between Q7 & Q5 – but then I loose it.
I have made the following measurements using a dmm:
See attachment
I feel like I am close, but just can't seem to hone in on it.
Does anyone have either a schematic or some suggestions?
Thank you very much for taking the time to read this post.
Steve
See attachment
Steve
