Magnavox 32MF338B/F7 has no power, blown fuse
  • CapLeaker
    Leaking Member
    • 8326
    Re: Magnavox 32MF338B/F7 has no power, blown fuse
    That depends on how much You want to get into finding shorted or open fets and diodes and maybe some resistors that changed value. Just hate to throw new parts at it and then have it blow up again. This jig should take care of that problem and no it isn't hard to make. The only trick is to wire the bulb in series, also the hot wire in and out of the bulb into a plug. The neutral isn't going through the bulb. That's it.
    • SurrealMustard
      • Jan 2015
      • 487
      • The United States of America
      Solved!
      ShopJimmy got a few extra MUT boards back in stock recently! This has fixed the problem.
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
