50 inch samsung plasma
  • beano
    • Aug 2013
    • 9
    • usa
    Dead no lights try replacing power supply still dead no lights
  • KevinCro
    • May 2014
    • 104
    Re: 50 inch samsung plasma
    Does it have any signs of life? Clicking, screen flashing, etc.?
    • Ltank
      • Jun 2013
      • 776
      Measure the DC voltages on output of P.S. You must have a low voltage standby either 5 or 3.3vdc. This allows the remote to power up set. If it's ok the measure Vs there should be a label on screen listing the voltages. If Vs is low, try disconnecting the P.S output and measure the voltage. A shorted Y or Z board can load it down. The meter negative lead ties to Chassis gnd.
      • nogger
        • Aug 2010
        • 190
        What is model number of TV ?
        What is part number of Power Supply?
        You need to provide this basic info so we can help you
        • Super360
          Samsung PLASMA PN50B530S2F DEAD
          by Super360
          Hi everyone I have this plasma here that has no standby light and is completely dead. I opened it up to see extremely dirty and dusty to which I cleaned but made no difference. So I checked all fuses good. I checked the standby voltage 5 volts good. Then I did that plasma control board test by shorting the pins(THANKS 2 TVTIMMY) and the tv actually turned on and made a sound. Does this mean I need a new motherboard?...
          12-16-2021, 09:25 PM
        • ChristianBr01
          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
          by ChristianBr01
          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
          04-23-2025, 01:48 AM
        • KYBOSH
          Samsung PN59D8000 Plasma - Dead Screen
          by KYBOSH
          Got my hands on another non-working TV this weekend.
          Person I got it from says he heard a load POP and the picture died.
          Nothing to see when I opened up the back.
          I found a single thread about this model on this forum and in it @dick_barton provided a very useful Fast Track Troubleshooting guide.
          I followed the steps and found that my power supply was good (good Va & Vs) but only after unplugging the X & Y Boards.
          I narrowed the problem to the Y-Sus board and found shorted IGBT (RJP30E3). There were also two other casualties...
          01-01-2023, 01:20 AM
        • porfyriadhs
          Samsung Plasma PS51D6900DS Bootloop
          by porfyriadhs
          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
          Thanks a lot !!
          10-19-2023, 11:31 AM
        • ArMaaN376
          Samsung PS51E550 Plasma TV
          by ArMaaN376
          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
          Opened TV cover & observed foll
          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
          How to confirm Y -Buffer board...
          06-19-2024, 04:05 AM
