Toshiba 46xv645u 1-Blink 2-Blink 3-Blink Upon Power Up..
  • Michale32086
    • Nov 2011
    • 1453
    Toshiba 46xv645u.. Plug it in, the power LED blinks 3 times..
    Let it run like that for a bit and then push the power button..
    I get 1 blink.. Pause.. 2 Blinks... Pause. 3-Blinks, then it goes into the 3-Blink repetition..
    When plugged in, Relay SR80 closes.. When unplugged, SR80 will open, then close, then open...
    Relay SR81 does nothing...
    https://www.badcaps.net/forum/showthread.php?t=44052
    This thread had some insight but I checked the fuses and resistor/fuses and everything is good...
    Going to check voltages next...
  • Michale32086
    • Nov 2011
    • 1453
    Re: Toshiba 46xv645u 1-Blink 2-Blink 3-Blink Upon Power Up..
    Looks like it's a blown cap on the Inverter board..
    Oh gods, please let this be an easy fix!!
    • Michale32086
      • Nov 2011
      • 1453
      Nope.. This is just not my lucky day...
      Replaced the blown cap.. Still have the 3-blinks...
        Ask yourself what caused the cap to blow? Is the fuse on that board OK?
        • Michale32086
          • Nov 2011
          • 1453
          I figured a power surge of some sort..
          I found two fuses and they check out..
          I know it's a crappy solder job, but the replacement cap is solid..
            Nah, that's just flux... the joint itself is ok... those are always tricky to do, as surface mounting a radial electrolytic is not optimal.
            Do you have 24V at the fuses, at both ends?
            • nicholas1110
              • Aug 2012
              • 127
              • usa
              Yikes, I don't recall ever seeing a bad cap on one of these samsung inverters. My first guess with the power related issue would be the q880 on the power supply. Just like the older toshiba power supplies where 3 ic are replaced on the power supply for the 3 blink code. There are also 2 47ohm resistors on the power supply that run hot and usually discolor the board. I have not seen one open but I'm sure it's possible with how hot they run. Can't remember the exact location but they are on the right near 2 mosfets( I think in my thread about the board I had the location).
              • Michale32086
                • Nov 2011
                • 1453
                Had to go get the grandkids from the bus stop.. I'll be back at the house in a few and will check what's been mentioned.
                Thanx for the replies
                • Michale32086
                  • Nov 2011
                  • 1453
                  Not sure what you mean by "both ends"...
                  If I have one probe on one end and the other probe on the other, I get 0v
                  If I have POS probe on either end and NEG probe to chassis GND, I also get 0v
                  This is with the unit plugged in...
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Definitely some discoloration here, so this is where I assume you mean ...
                    • nicholas1110
                      • Aug 2012
                      • 127
                      • usa
                      Yep those 2 resistors should be 47ohm when you test them.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        I got two hours before the wife gets home and I have to clean up...
                        • CapLeaker
                          Leaking Member
                          • 7964
                          plugged in and the TV turned on? That's not good then.
                          • Michale32086
                            • Nov 2011
                            • 1453
                            As "turned on" as this unit will allow itself to be..
                            I have noticed that the sequence of blinks does NOT appear to be related to the pushing of the power button...
                            It appears that the sequence is thus...
                            8 3-Blinks, 1 1-Blink, 1 2-blinks, rinse and repeat...
                              Ok, post a picture of the connector going between the main board and power board - include the legend next to it, indicating which pin is 5V, etc.
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Attached
                                  Ok, what do you get on pins 5V1, and PWR_TV?
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    5v1 = 5v
                                    pwr_tv = 3.3v
                                      Ok, and what about 12V?
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        All 3 show 12v
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
