Toshiba 46xv645u dead power supply
  • nicholas1110
    • Aug 2012
    • 127
    • usa
    Having a bit if a hard time with this toshiba. I have repaired this tv 3 times for the same issue. The symptoms of the tv are dead, no standby voltage. So let's start at the beginning of the story. First repair attempt, I replaced the open cement fuseable resistor r850, and q880 which is str-y6456 ( was not shorted). Sent the tv back to the customer, tv ran for about a 2 weeks. Tv came back. Same r850 fuseable resistor was open. This time I ordered a repair kit, which came with r850, bridge rectifier d820, and 2 47ohm resistors at r827, r828 ( which are running hot as the board has browned near them but they show 47ohm still. Tv ran for about 5 days this time, and back with the same r850 resistor open. There are no shorted mosfets. My only thought is maybe the 2 150uf 450v caps.
    So main question, what can cause this fuseable 1.8ohm resistor to keep opening?
    I have 3 more of these TVs in my shop right now with the same issue, and I'm hesitant to send them home. I've let them run here for over 48 hours now strait with no issue.
    Any help would be appreciated.
  • nicholas1110
    • Aug 2012
    • 127
    • usa
    Re: Toshiba 46xv645u dead power supply
    Forgot to add power supply part number is v28a000962a1 pe0702A
      Please upload the pictures of the whole backside of the TV, and also the bottom side of the power supply board.
      • nicholas1110
        • Aug 2012
        • 127
        • usa
        For some reason my phone will only let me do one photo at a time
        • nicholas1110
          • Aug 2012
          • 127
          • usa
          Another
          • nicholas1110
            • Aug 2012
            • 127
            • usa
            I don't have one with the back off the tv right now, I took these before I repaired the board and put the tv back together.
            I've searched around the forum and found a couple threads about this board but no definitive answers.
            • nicholas1110
              • Aug 2012
              • 127
              • usa
              Ok, found the issue. Relay sr80 has dirty contacts in it causing the r850 to open. I have opened the relays in the TVs I had running, cleaned them up and should be good to go. Hopefully this info helps the next person with this issue.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Interesting fix thanks for posting
                • Michale32086
                  • Nov 2011
                  • 1453
                  I just got one of these in.
                  OP, did you get 3 blinks on the Power LED when plugged in???
                  • nicholas1110
                    • Aug 2012
                    • 127
                    • usa
                    These model, the green light will blink 3 times then repeat approx 2 times when tv tv is first plugged into power, or not be powered on for a certain amount of time.
                    Did yours have the bad fuseable resistor? If so make sure you replace the sr80 relay or it will fail again. You can also open the relay and clean the arc marks off the contacts.
                    • nicholas1110
                      • Aug 2012
                      • 127
                      • usa
                      Mine came to me as dead, no signs of life when first plugged into power. Opened up to find the fuseable resistor open.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        The SR80 relay closes upon plug-in. Then, after unplugging, it opens, closes and opens again..
                        The SR81 relay just sits there...
                        Which part number is the fuseable resistor??
                        Are they they ones marked??
                        Thanx for the reply...
                        • nicholas1110
                          • Aug 2012
                          • 127
                          • usa
                          The resistor is r850, it is next to the relay. Since you have signs of life it is most likely good. It should read 1.8ohm or so. When it's open it's much higher, but if your relay is functioning then the resistor is most likely good as it feeds power to the relay. There is a fuse in the upper right corner of the board, check that fuse. The other issue I've had with this board is the q880 regulator. Which sometimes will open that fuse when it fails. Or sometimes just contestant 3 blink code like the older toshiba power supplies
                          • Michale32086
                            • Nov 2011
                            • 1453
                            OK, this is really weird...
                            First off, R850 does show 1.8ohm (1.9, but close enough). So I am guessing we're good there...
                            Here's the weird part..
                            I let the Power LED blink for a while. 3-blinks 3-blinks 3-blinks for at least 7-9 repetitions..
                            Then I pushed the power button..
                            Power LED blinked once. Then blinked twice.. Then went back to the 3-blink mode..
                            Since this is obviously not related to your issue, I don't want to hijack your thread..
                            I am going to start my own thread on this, but would appreciate any insight you may have, since you have worked on more than a few of these.
                            • BackYardBert
                              • Jan 2017
                              • 2
                              I have the same dead TV issue with the same power supply board (V28A000962A1) in a Toshiba 52XV645U. Bridge Rectifier @ D820 bad. Ceramic resistor fuse @ R850 bad. 47Ohm resistors @ R827 & R828 Ohm out fine but have blackened the PCB. I want to replace or clean the 5V Relay @ SR80 as you suggest. I can't find a replacement. How do you clean the switch contacts? I assume you desolder and remove the relay from the board to remove the cover. Then how did you clean the contacts? A spray? A file? Thanks if you get this!
                              • MvZiC MaN
                                • Apr 2017
                                • 19
                                I have the same Board from a Toshiba 47ZV650U. Same problem,
                                No power at all.
                                Tested R850 and it is Open. Bridged the contacts to test and it powerd on just fine. But i also noticed the Resistors on mine @ R827 and R828 are Blackened around them. Did you ever Find out the cause or Fix the issue? Thanks!
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  Read post #7
                                  • MvZiC MaN
                                    • Apr 2017
                                    • 19
                                    The contacts on SR80 dont look dirty too me. Will upload a pic if i can yet.
                                    Edit: Heres the best photos i could get.
                                    Can try to get better ones 2mrrw.
                                      The relay contact are blackened and pitted.
                                      • MvZiC MaN
                                        • Apr 2017
                                        • 19
                                        Does that mean i need to replace the Relay as well? or is there a certain method to Cleaning/restoring the contacts of the relay?
                                          Toshiba Tecra R850-1JN Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra R850-1JN Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R850-1JN boardview and R850-1JN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 09:40 AM
                                          Toshiba Tecra R850-14C Specification for Upgrade or Repair
                                          This specification for the Toshiba Tecra R850-14C can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R850-14C boardview and R850-14C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Tecra...
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
