LG 50PK350 Clicking
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    LG 50PK350 Clicking
    Hi, I have this 50 inch LG plasma TV and when i try to turn it on it clicks then then the screen flashes quickly on then off again, It repeats this a second time then just clicks a few times. Can anyone suggest how I troubleshoot this set? Here is a video showing the fault and also a few pics of the back of the TV,
    http://tinypic.com/r/2u5rxxt/8
    https://lh6.googleusercontent.com/-z...217_225601.jpg
    https://lh5.googleusercontent.com/-s...217_225545.jpg
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: LG 50PK350 Clicking
    have u checked any voltages ? VS/VA on the power supply readings ?
    • Easky15
      • Sep 2013
      • 285
      • Ireland
      VA reaches 60 then quickly powers off, VS reaches 208v
      • sordids999
        • May 2013
        • 2161
        • uk
        so VS is steady but VA drops ?
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          No they both drop when the set clicks off.
            Checked the common 22 ohm resistors for possible signs of failure? (They usually fail open)
            • Easky15
              • Sep 2013
              • 285
              • Ireland
              Where is the 22 ohm resistor? Sorry I'm not the best at fixing these, I just come on here and ask the experts then do what they say.. :-)
                Power board, two white devices marked "5W22RJ" or something similar...
                • Easky15
                  • Sep 2013
                  • 285
                  • Ireland
                  ok one is showing as 21.7 ohms and the other isn't showing anything so i guess it is blown. :-)
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    i would change both anyway
                    • Easky15
                      • Sep 2013
                      • 285
                      • Ireland
                      Just found a board upstairs with similar looking components, Can you look and see if they are the same, I think they are but wanna be sure.
                      https://lh6.googleusercontent.com/-d...218_212148.jpg
                        It looks OK. Test a few times - some resistors aren't suitable for the application they're used in and will fail after a few tens of power on/off cycles. If that's the case you'll have to order a suitable replacement.
                        • Easky15
                          • Sep 2013
                          • 285
                          • Ireland
                          Fixed...... Thanks again... ;-)
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Please attach the files, the host you used is prone to disabling images.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • Easky15
                              • Sep 2013
                              • 285
                              • Ireland
                              You mean google or tinypic?? I use google cause i have my phone set to auto backup images to gogle drive so its alot easier and faster to just go there then copy link.. ;-)
                              • wolf1976
                                • Oct 2023
                                • 113
                                • Ελλάδα
                                hi i have the same tv and there is the same problem clicking
                                the one of two resistors is open i dont have change it yet to see if the problem fix
                                but from where can cause this problem from pure capacitors maby ?
                                does anyone know ?
                                • wolf1976
                                  • Oct 2023
                                  • 113
                                  • Ελλάδα
                                  in my case i change the faulty resistor and the problem clicking continues
                                  the two resistors are ok now
                                  • Sisko
                                    Onkyo-593 No power and now clicking sound
                                    by Sisko
                                    Hi all!!
                                    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                    10-03-2025, 02:18 PM
                                  • slimmy182
                                    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                    by slimmy182
                                    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                    Looking on google I found this:...
                                    01-14-2023, 11:55 AM
                                  • GRANDGG
                                    LG 42lw4500 flashing red light , wight light , 2 clicks
                                    by GRANDGG
                                    Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                    05-09-2025, 12:27 PM
                                  • beetle1303
                                    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                    by beetle1303
                                    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                    01-13-2025, 08:49 PM
                                  • B0r1s
                                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                    by B0r1s
                                    PSU - BN44-00878A
                                    Symptoms:
                                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                    A weak clicking sound was coming from the transformer.
                                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                    Progress:
                                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                    01-17-2023, 04:58 PM
